Coasting in Neutral... what if you can't come to a full stop after?
So... today I was traveling down my all-time favorite road.
They just repaved it last weekend... omg. so nice. :D And it is huge up and down hills. The first hill you can coast down for forever, and then a sharp incline to a stop light. I coast down, but can't shift to neutral because I know I can't make it to the top. (I've tried) After that, there are some short hills followed by a HUGE valley. I can start coasting way back, reach the decline without losing any speed, then increase speed as I go down and retain 80% of that on the way back up. I can make it far enough to get to the stoplight about 1/4 mile after it starts to level back out. Today, for the first time, I decided to try going down this hill in neutral because I noticed the light on the other side of the valley had just turned red... bad idea. I was about 10 car lengths away when the light turned green. While this experience has turned me into a huge believer in Neutral Coasting (as soon as I shifted into N, I sped up by 5mpg, with no change in grade)... it also made me think... because I had heard that you should come to a complete stop before shifting into drive, I found myself abruptly coming to a full stop, so I could hurry up and shift into drive without the cars behind me catching up. So I supposed my conundrum is... what is the best plan of action when you are coasting in neutral and find yourself in a position that doesn't favor you stopping and shifting back into drive? My thoughts are put on the hazards and pull off onto the shoulder, shift, then merge back into traffic... well, what if there is a curb on each side of the road? Anybody have any thoughts or suggestions on any of this? |
Where did you read that you have to stop to put it back into drive? Just rev match as well as you can and put it back in.
really? What do you mean by rev match? match them to what?
I thought I read it on here... wherever it was it was a long time ago.
Rev match just means to rev the engine up to match the rpm it will be at once it is in gear. This is always a general guess with an automatic. Really, as long as you don't feel the car jerk as it goes back into gear, you are fine.
I've been neutral coasting the last couple weeks in my automatic. I haven't noticed much car jerking going back into drive. There were only a couple small instances of this. I've found it very smooth.
HHINLA |
Most cars handle the shift into Drive with no problems. The only one that gave me issues was an '08 Kia Rio. (It had other problems anyway; if you shifted from Reverse into Drive if you were rolling backwards at all, it would lock up the tires. I've never had an auto do that before.)
I'll echo what others have said. If it finds the right gear and goes into Drive relatively smoothly, you're fine. |
I always give the car a couple seconds to "rev match" after putting it back into drive...especially when neutral coasting at higher speeds (highway or steep downhills). When going from neutral to drive you can see the rpm's go back up to around 1500 from approx. 500...then use the accelerator to ease back up to speed.
In my situations, I simply drop it back into neutral, the transmission does its own version of rev matching, it will spike the rpms to lets say 2200 befor lowering back down to 1700. SO basically I shift and wait a couple of seconds before engaging the accelerator again.
4 months in to P&G @ highway speeds, no ill effect or wierd noises. |
My wife's car is an automatic and anytime I nuetral coast in it I just shift back into drive and it always shifts back into gear smoothly, then I just accelerate as normal.
well, I tried the rev matching and it worked. Nice and smooth.
but if I don't push the accelerator, the car jerks awfully. (in reply to the Kia comment) I can shift from reverse to drive without it jerking.... just not from neutral to drive while going forward... weird. |
Each vehicle has a sweet spot where it will shift in Drive without thumping or jerking. I find that 38 to 44mph works for the three automatic vehicles I have. I also wait for the torque converter to lock up before accelerating. It takes a couple extra seconds. It doesn't hurt to give it a 250 to 500 bump in RPM off idle before shifting to drive, BUT leaving it alone also gives good results.
"Rule of thumb", according to me, is to shift to drive about 5 to 8 mph above where the car normally shifts to overdrive. All of you should know where that is by memory if you practice hypermiling. That way you are shifting to Drive when the vehicle will be in overdrive and NOT the next gear down - probably where the thumping and shuddering comes in. |
i have a rental this week ( doing some field work in Baton Rouge) - so i am playing with automatic tranny ( mine is manual in the Altima)
car is an 08 Ford Fusion - V6. Really nice BTW - for the 10 mile drive from hotel to site - getting about 30 mpg - mostly 4 lane highway with some lights on it. Have had no issues with the N to D shift - i have been tapping the gas just before i shift back ( psuedo rev match) no noises and no odd sounds. I have even been playing with EOC to stop lights a little. based on what i have seen here - ( and supporting what others have said) this is probably a bad idea - I know each car is different - but for the Ford Fusion - automatic - the tranny gives off a FOUL SMELL if you EOC to stop lights - indicating that the tranny is not being properly lubricated. Neutral coasting - not an issue. EOC with this particular car - Bad idea. Steve |
Mine only likes to go back into D if Im going 30 mph or less, then it does so seamlessly. Anything faster than that and it drags you down, takes a few seconds to run through the gears to get itself back into the right gear then another couple seconds to decide to lock the TCC again. Rev matching before shifting into D makes it worse. So needless to say, I only go to N when I know Ill be going back into D when Im going slow or stopped.
I have been doing this and it has been working really good...
except that I have only been doing it where I will shift back to drive approaching a yeild or a turn, or a stop that I can just not make it to in N. I haven't tried doing this at speeds over 20mph, but I might try it sometime in the future. |
I just stick it back in Drive while coasting, even at 60mph sometimes.
It just shifts back in the final gear real quick and I accelerate up the next hill. |
I P&G in my Monte all the time, auto trans. It's no problem at any speed to go from N to D, although I have found that if the engine and trans aren't warmed up enough there can be a bump and a RPM rev going from D to N. Anyone have this problem and what can I do about it?
