Coding newbie.
I just about have my mpguino assembled, have all the soldering done, just need to hook everything up & trace vss/injector wires.
however this is going into a v6 4runner, what am i going to need to tweak in the source code? i'm kinda lost... |
I'd either look for a variable the multiplies the for the number of injectors or just not bother and use the fuel trim adjustment to do it for you.
