Color matched duct tape for the win!
Just spruced up my grill block with some color matching duct tape. I love it!
http://i196.photobucket.com/albums/a...grillblock.jpg |
the red right???
it looks great....cant even tell! |
Works a lot better than on my Probe, that's for sure.
is your lower grill block opening in the center because you have a/c too? if you don't have a/c you would be better off having the oppening all the way on the passenger side since the rad is only on that side
Correct. It is centered becasue I still use AC every now and then. Although it is not an issue for me, my wife requires me to use the AC when she or my son are in the car.
Do you have the chin area blocked off, so all the air goes through the radiator? If so, you might even see an *improvement* by blocking off the upper grill -- or do you have it blocked off already?
looks like its blocked off with clear plastic to me
good work! duct tape is the greatest tool ever |
