Commy - Holden SV6 Sportswagon
7 Attachment(s)
Hey Everyone,
Hope this is the place to post it. I've attached some pictures of some mods I've done after having a read of this forum. This car I've had for just under 6 months and I've already had a play around. 1) The day I bought the car (ute in the background) 2) Removed the stock SV6/SS rear diffuser, it had a fake mesh that was impossible to wash haha 3) Replaced it with a Pontiac Style G8 GXP diffuser, still need to remove it again and fix some mounts as its not a direct fit, lots of dremel action 4) Ordered and fitted 2012 Model VE Series 2 Commodore rear tyre spats/deflectors - cost $30 for the pair, 1 screw and two stainless steel pop rivets hold it in for both sides. 5) After reading about smooth bumpers I thought up a easy stylish way of filling in and smoothing the flow of air around instead of into the inset fog light housing, I ended up with a Aluminium Channel, two Stainless 316 Screws and some heavy duty trim push pins with custom cut acrylic panels. Overall car to date sitting at home :) Next mod is a HDT style Carbon Fibre over Fibreglass front upper grille, My thoughts is smaller opening and it might allow me to make a sort of custom active grille shutter behind the opening. Thanks for looking :) http://ecomodder.com/forum/attachmen...4&d=1521023736 http://ecomodder.com/forum/attachmen...5&d=1521023767 http://ecomodder.com/forum/attachmen...6&d=1521023795 http://ecomodder.com/forum/attachmen...7&d=1521023830 http://ecomodder.com/forum/attachmen...8&d=1521023876 http://ecomodder.com/forum/attachmen...9&d=1521024047 http://ecomodder.com/forum/attachmen...0&d=1521024095 |
Nice car.
Welcome to the site. What kind of mileage are you getting with the Commodore?
I get about 12L/100Km or 19.60Mpg, that is all around town at 40-50km/h here in Australia. When I first bought the car before I did any modification I did about a 6 hour mixed speed and highway drive and got about a 6.8L/100Km or 34.5Mpg, The car has a 5 Speed Auto and I used Cruise Control alot of that trip. The engine is a Quad Cam with Quad variable Cam phasing - 3600CC GM High Feature V6 LY7 with 195Kw power so not too bad, the car is on the heavy side at around 1900Kg's or 4200 Pounds. |
Not too shabby. :) Do you have a goal of what mileage you'd like to achieve?
2 Attachment(s)
Recently I've fitted this new upper grill, its supposed to be like a HDT / Holden Dealer Team type aero grill but its made buy another manufacturer, its real carbon cloth over a fibreglass body and was noticeably a little lighter than the the stock grille, I am thinking it would in this slot style be like a partial grille block :)
Before: http://ecomodder.com/forum/attachmen...1&d=1522461089 After: http://ecomodder.com/forum/attachmen...2&d=1522461114 Really happy with the result, its suits the colour of the car too. |
Not many good looking cars left. This would be one of them. Best of luck. It matters mightily, IMO, that we like our particular car. Economy is a matter of pride, as a start.
