EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Compensating for New tyres? Calculating the % out my milometer will be.. (https://ecomodder.com/forum/showthread.php/compensating-new-tyres-calculating-out-my-milometer-will-20143.html)
320touring 01-18-2012 07:31 AM
Hi,
I've just replaced 2x 205/60/15's with 1.6mm of tread
for 2 new tyres of the same size with appox 9mm of tread.
My BMW takes its milometer feed from the diff, so the increased circumference of the new tyres will change that..
whats the best way to factor in the % difference, or does anyone know a way to calibrate an electronic speedo/milometer?
thanks
gone-ot 01-18-2012 02:00 PM
...does Scotland have "mile-post" markers? If so, simply drive at steady 60 mph (using cruise-control helps) and measure the time (stop watch) between 1 and 2 mile posts.
MPH(x) = 3600 / sec for "1-mile" marker
MPH(X) = 7200 / SEC for "2-mile" marker
...the "correction" factor (%) will be:
% = MPH(x) / 60 mph or % = MPH(X) / 60 mph
euromodder 01-19-2012 12:21 PM
Originally Posted by 320touring (Post 280499)
I've just replaced 2x 205/60/15's with 1.6mm of tread for 2 new tyres of the same size with appox 9mm of tread.
You could use a GPS to calibrate the meter.
BMW likely calibrated it with fresh tyres though.
320touring 01-19-2012 02:41 PM
cruise control?unfortunately not...
cheers for the formula though:thumbup:
Fair shout- I may try to get my dad's one..
D.O.G. 01-21-2012 03:28 AM
The previous owner of my Mazda Astina (323F in Britain) fitted smaller profile tyres (195/50 15 verses 195/55 15).
I checked the speedo against my GPS on the motorway and it reads about 4.5% fast, as expected.
I checked the odometer against a measured 5 kilometer "speedometer test" sign posted on the motorway and found it to be accurate.....Huh?:confused:
I checked the odometer against the GPS driving to work. The GPS said my commute is 51.9km, my odometer said 52.0km, close enough to perfect. Again I say.......Huh?:confused:
My point is, don't assume the speedo accuracy reflects the odometer accuracy, as I always did in the past.
If you really have to adjust your speedo, this might help.
Speedo Corrector MkII Kit "Kit Back Catalogue" - Jaycar Electronics
I haven't tried this kit myself, but it sounds OK.:rolleyes:
