EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   Compensating for tire size (https://ecomodder.com/forum/showthread.php/compensating-tire-size-7065.html)
junker 02-09-2009 09:40 PM
I have slightly oversized tires on my car which throws off my speedometer. Until now it hasn't mattered but since I am installing the MPGuino it is an important factor. I have the circumference of the original tires and the current ones and I need to factor that into the MPGuino as well as keep it in mind when calibrating.
What would be the best place for me to factor this in... dialing in -or- hard coding it?
Than You.
dcb 02-09-2009 09:52 PM
in the setup screen, adjust vssPulsesPerMile down by the percentage that your speedo is low. Compare the results with some hiway markers over many miles and fine tune.
