complete exhaust replacement on the Paseo
Well, the time has come. The existing exhaust on the Paseo is pretty much shot and needs to be completely replaced. I don't want to deal with this again anytime soon so I'm looking to remake it with stainless. However, I also don't want to spend a small fortune on the system so I'd love some recommendations. I'm looking for anything useful here. Mufflers? Cats? Resonators? Flex pipes? I'm doing everything from the exhaust manifold back so there are a bunch of parts that I'll need.
are you going to own it long enough for the extra $$ on SS ?
I don't anticipate selling it anytime in the near future. It only has 75k miles on it. Plus, in my wonderful salt using state a mild steel exhaust lasts about 2 years max.
Why would you recommend a 1/4" increase in pipe diameter?
Thanks, but I would have to disagree. My engine never sees more than 3000 rpm which is half of the max rpm. So, the exhaust is already oversized as far as I'm concerned. Thanks for the suggestion though.
Well if its already oversized you wouldnt mind a 1" pipe on there then?
I have definitly thought about downsizing. The stock size is 1.75" and I've thought about 1.5". The problem is finding components that are that small. If I could find a 1.5" in/out CAT, resonator (or glasspack muffler) and muffler I'd consider it. Even finding straight SS pipe and mandrel bends in that size can be difficult. I'd rather not have to deal with a ton of adapters (1.5 -> 1.75) just to piece the thing together either.
Keep the suggestions comming though! :) |
http://www.stainlessworks.net/cart/fabrication.php
Poke around the whole site, Stainless works has the flex pipe etc in stainless. They can also make up a whole system from you using the old one as a pattern. I have been happy with the pipe I have bought from them. |
Thanks. I checked out their site which does have a lot of stuff on it. However they are a little pricy. Their mandrel u-bends are $40/ea for 1.75", yikes. I can get u-bends from http://www.mazzurisuper.com for $20/ea. The price on straight pipe is similar, but I'm hoping to pick that up locally to save on shipping.
I could really use some help finding a good (idealy stainless) pre-muffler/resonator and a final muffler. Aftermarket resonators seem to be awfuly overpriced. Right now I'm just using a cheapo $20 glasspack inline muffler and it works alright for quieting things down that extra bit. Any suggestions or websites would be helpful. |
Daox,
thanks for the link. I have only gotten the straight pipe so far, if I need bent I will use your place. |
http://store.racing-solutions.org/180deu.html Amazing what you find when you look. |
make sure the size you want is ID and NOT ,OD
Sorry if I came across a bit harsh.
