Completely unexpected MPG results
In advance, sorry if this should go under "Instrumentation" but that forum looked completely dead.
So I just bought a ScanGauge for my Honda Accord and I had used it for the "Daily" MPG tracking features prior to first fillup, and it seemed consistent with results I had previously been getting without instrumentation. Today I filled up the tank completely and followed the instructions for calibrating the device to a full tank of gas. I also reset my trip meter since I've noticed the SG does not recognize coasting with the engine off. One shift of food delivery with Uber Eats runs me 52.0 miles. I ecodrove the hell out of that car, especially considering that I was also working. SG reports 31.5 MPG for the tank which is slightly above average for me, but I figured it was pretty accurate now that I can monitor the MPG in real time. So I go back to the same gas station, same exact pump, and somehow the car manages to take 3.43 gallons to fillup. Barely 15 MPG. The numbers make zero sense to me, can someone explain what might have happened? I filled to the first "click" each time as SG instructions say plus I really don't want to screw up the EVAP system. I don't think its possible to have gotten 15 MPG. |
Short fills are wildly inaccurate vs filling at 1/8 tank or so.
Over time, with many data points, a more accurate picture will be painted. But in the short term there will be wild variations in spite of efforts to use the same pump, same click, and all that which should still be done. |
It does not really matter whether the gauge is off or not.
If it is off, it will underreport or overreport by the same margin every time. You'll still learn what works and what doesn't. Variations in fill-ups can be huge. I've had differences of 7 liters (judging by the point where the fuel needle leaves the F), that's almost 2 gallons. Fuel pump readings are useful as they give an accurate reading of the amount of fuel you tanked (irrespective of whether your tank is brimmed or not), and will over time become fairly accurate in aggregate. After several fillups you can use it to recalibrate your gauge. Tank-to-tank data is not very useful, and partial fill-ups increase the margin of error. |
Short fill. Also try calibrating you SG using a 3 fill average.
About the only way to be reasonably accurate with short fills is to top off the tank. I always fill the tank until gas is visible in the filler neck and my mileage still varies by a few MPG sometimes but there's going to be a certain amount if variation from tank to tank simply because of weather, terrain, etc. In most cases with my Versa I can get between 1-2 gallons in after the first click. On the Escort it's probably at least 2 gallons. Things like pumping speed can effect when the pump will click off. At the station I use I've noticed that the pumps will pump at different speeds depending on how many people are using the pumps at the time. The faster the pump is pumping the earlier it will click off.
you can fix this by lining up the edge of your mirror with a fixed object this is what i do I even do it when i park my SUV so i don't crash into the curb when parking.. as not to damage the aluminium suspension in the front(even if you hit it slowly it could damage it or pop a tire) also wait a min for the sloshing of the fuel if it's close to being full.. I all ready tested this as long as i fill up at my "home station" even if i filled up and only drove 70 miles it has very little effect on the results.. (as sometimes I can get CHEAPER chevron gas or mobil elsewhere i can save an extra dollar or two doing that) overtime it will have very little effect on average MPG. my averaged dropped to 22mpg as I have only been driving City only.. it sucks i have to drive slower since the ground is wet and my tires are pretty worn out I rather spend a few $ on gas driving slower then have to pay thousands for damage repairs if I was to spin out or something $ is better then spending $$$$ |
filling
Short of having a removable racing fuel cell,which you could weigh,and go by fuel mass,we're all kinda SOL as far as accuracy goes now.It's very frustrating. |
Of course this is only as good as the pump's meter. There are regulations on the accuracy and testing of that. |
next time
I'm filling my truck 6-times a year.There are variables in flux during that time frame,which might not sort themselves out for an entire year.The fuel itself wouldn't even be the same for the duration. Driving a single mod at exactly the same condition for an entire tank full would be one thing.Driving various mods for 50-miles would be another animal.Overnight temperatures alone would skew data. The only way to know is to test.Other than that all we can claim is informed speculation. Some station owners can tell you the current temperature of the fuel underground or above ground.A stainless steel 6" stem thermometer,placed in the filler neck will tell you about the fuel delivered.These thermometers can be calibrated in an ice bath.You'd need to know the temp of the fuel already in the tank.Stratification.The coefficient of thermal expansion for motor fuels is available online.Dry bulb temperatures should be monitored during testing.Along with coolant,transmission,differential,tires.Rain or snow.Wind,wind direction.Topography.Road curvature.Road surface.Road temperature. According to the SAE,your vehicle needs to be warmed with 50-miles of driving at 50-mph,before testing ever begins. |
Thanks to everyone who chimed in. The station I frequent does have a slight slope so that probably contributed, along with pump inaccuracies. I'm going to assume the SG was probably closer in accuracy than the classic fillup data. I was really hoping the SG would enable me to get a better understanding of how much gas I'm using on a "per shift" basis with food delivery, and to isolate that data from my routine driving to/from my job (whenever that comes back, thanks corona) but it looks difficult to impossible if I need to drive it down close to empty. Oh well. I feel like I kind of wasted money on this device. I already know how to save gas -- keep my foot on the accelerator as little possible, brake as little as possible, and shift into 5th ASAP. |
You don't need to go close to empty, it's just the fastest way to get the most accurate calibration. Longer distances beteen inputs make for more accurate results, just like a 36" level is more reliable than one on a keychain, and a 72" level is even better.
You won't get accurate "per shift" data until you're calibrated. If you admit that and go deeper into your tank a few times to get it calibrated, you'll start getting accurate numbers, which will pay off in more ways than simple shift data: a well calibrated gauge will teach you more about your car than a generic "keep my foot on the accelerator as little possible" rule. There's a time and a place for everything, and your car, tires and feet are different from other cars, tires and feet. Once you're calibrated, go ahead and reset the long trip after every shift. Have fun! But the short trip numbers will teach you more about how to get the most out of your car than any list of short fills can ever hope to. |
All good advice.
Trying to fill up the tank after using only a small proportion of its volume will excessively expose the driver to the vagaries of the process: angle of the sitting car, temperature of the fuel, peculiarities of the pump, etc. IOW, if you habitually fill up a 3/4 full tank vs a 1/4 full tank, your error factor from the fill-up process itself is significantly increased. When I first got my Surge Guard, I followed some sage advice and adjusted for only about half of the differential between the pumped-gallons vs SG-predicted gallons at each fill. This way, it prevented a lot of under-and-over-shooting of the target. Most of my miles are on the highway under repeatable conditions, and my SG routinely gets me to within a half gallon or so at each fill. The error is only a percentage point or three over or under. It's close enough that I can't do any better because of the maddening myriad of things that affect fuel economy at any given time on any given trip. Incidentally, I haven't adjusted the "gallons used" factor after maybe 10 iterations when I first got it. After that, it has been amazingly accurate as set. The SG has certainly improved my ability to squeeze all the distance I can out of a gallon of RUG (although I don't employ enthusiast extremes such as coasting-with-engine-off, etc). It's even allowed me to manage my all-important speed better because I can calibrate the SG to show my exact speed vs the vague analog speedometer in my particular car, especially when I changed the tire size to a slightly taller aspect. The SG is not perfect, but it's as good as it gets as far as I can tell. |
