Compression test oops
I did a compression test on my car and got very high readings. (Book says 192PSI, my gauge showed around 220PSI)
Afterwards I realised I didn't hold the throttle open while doing it. Now, wouldn't that have given me readings *lower* than expected?:confused: |
As far as the higher comp. numbers I would be happy. Compression gauges tend to vary, so as long as the cylinders are reading close to each other your fine. |
Carbon build-up on the crown of the pistons will raise your compression as well.
It could have carbon buildup, the head could have been shaved, could have been bored. etc etc
If you suspect carbon buildup, try using a spray bottle to put a little water into a vacuum connection. Water injection works surprisingly well to keep an engine clean.
Not to start an argument,
Boring a cyl normally leaves the compression pressure the same, unless the head has a squish band. O.P. , I guess you were checking an older engine to see if it has excessive blow-by? As in wore out low compression? Ecco driving tends to build carbon on the piston crowns. Don't worry if the comp is high as long as its not pinging due to detonation. |
Jason, how so? (the fact that comp stays the same)
With a squish band type head (typ for 2 strokes and some diesels) the cyl volume is compressed into a small dome 1/2 the size of the cyl Dia. Boring the cyl doesn't change this volume, just increases the starting volume that gets compressed into the pocket. In that event the final pressure really goes up. Now you're thinking "But Jason, every engine I've ever had bored came back with more compression!" That is due to the fact that the head was at least cut a bit to clear it up, usually some more to raise the compression ratio for a few more horses. Either way, the higher compression can cause detonation issues and needs to be watched. Dumping the EGR will help, as will a bit of ATF misted down the intake at half throttle. You may want to disconnect the cat before doing that as it throws ALOT of black carbon out the exhaust. |
Math time:
94mm bore X 71mm stroke, 1mm deck height, 55cc combustion chamber, flat-top pistons. Deck volume = 94 / 2 * 94 / 2 * 3.14159 * 1 ~= 6939.77 mm^3, or 6.9 cc. Swept volume = 94 / 2 * 94 / 2 * 3.14159 * 71 ~= 492723.83 mm^3, or 492.7cc Fixed volume = 55 + 6.9 = 64.9 Fixed + swept = 64.9 + 492.7 Compression ratio = 492.7 / 64.9 = 7.591 : 1 Change the "94" in the above to "96"-- 96mm bore X 71mm stroke, 1mm deck height, 55cc combustion chamber, flat-top pistons. Deck volume = 96 / 2 * 96 / 2 * 3.14159 * 1 ~= 7238.22 mm^3, or 7.2 cc. Swept volume = 96 / 2 * 96 / 2 * 3.14159 * 71 ~= 513913.86 mm^3, or 513.9cc Fixed volume = 55 + 7.2 = 67.2 Fixed + swept = 67.2 + 513.9 Compression ratio = 513.9 / 67.2 = 7.647 : 1 So an increase of 2mm bore (0.080") on a very mild two-liter four-cylinder (in this case going from 1971cc to 2056cc) would raise compression by one-twentieth of a point. The effect should be larger if the CC volume is lower, giving a higher initial compression ratio. It's not a huge effect, but there is an effect. -soD |
Hmmm. The (cheap) gauge could just be 'out'. The main thing is that all cylinders are pretty similar. I shone a torch down at the piston crowns and to my amazement they're all very clean and shiny.
