EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   Confused over "Current MPG" (https://ecomodder.com/forum/showthread.php/confused-over-current-mpg-7181.html)
Nevyn 02-20-2009 11:50 AM
(Yes, I'm aware; I'm dense.)
I've been pondering this for a while, and want to make sure I'm on the right track. are the "Current" numbers in the MPGuino for "Current Trip?" If not, what are they? I can't seem to decide.:confused:
The mockery may commence after the question is answered.:D
wagonman76 02-20-2009 12:54 PM
"Current" on the mpguino means total since the last time it timed out (default timeout is 7 minutes). Shut the car off and let the mpguino time out, and the "current" numbers start over at zero.
Nevyn 02-20-2009 01:13 PM
So it's "sort of" trip, but not a 'true' trip thing. Makes sense. Thank you!
dcb 02-20-2009 02:11 PM
I don't know if I would categorize it as "untrue". If I'm in the store more than 7 minutes it resets is all. It's a "true" trip with a "true" auto-reset feature :)
Nevyn 02-20-2009 02:51 PM
True. ;) You say "gahzeundheit," I say "Watch your mouth!"
I think of "trip" for going to + coming from a destination, as that way the climbs/descents balance each other. But I'm not setting the timeout to 8 hours... :p I don't know that I can come up with anything better either.
Just to be clear, I'm not faulting your choice of wording or code design - it make perfect sense (now), especially in a pre-1.0 release. :cool: :thumbup:
gascort 02-20-2009 10:35 PM
just reset the tank each time if you want that... I've been using tank mpg for my daily commute.
Nevyn 02-21-2009 11:03 AM
Yeah, been doing that too. However, I'm working on a "Distance to Empty" function, so resetting tank constantly isn't good for that. I'll get there someday.
