Connecting car alternators in parallel
What happens if I connect two car alternators in parallel? Can I connect three or four alternators in parallel? I just want a cheap way to increase power. I need 5.5kw for recharging a battery pack.
I have no idea, but I would guess that it would work as long as the one alternator isn't enough to get voltage up to 14-ish.
Sounds like a neat idea - what's the strongest single alternator you can find? |
Oh, and this thread should be moved to Ecomodding Central.
Hi Guys,
I thought i would throw in my .02 here. I'm a computer and systems engineer, so i have a little bit of insight here. I'm gonna say, you could run into problems. Most modern alternators are setup for active (computer) control. They are designed to top up your battery, and then run at the lowest level sufficient to maintain high voltage. If my battery is charged, the alternator will keep the voltage at around 12.7 volts. If the battery is discharged a bit, it'll charge at 13.5v. If the battery is very discharged, it'll charge at as high as 15V. The problem that i can see you running into, is that the first alternator to kick in will bring the voltage up above normal battery voltage. This will prevent the others from running. This alternator will run at the highest operating current it can, until the voltage sags down to regular battery voltage. Then the next alternator will kick in, and so on, until you are maxing out all your alternators. You won't be sharing the load between all of them. You could also cause controller instability, whereby the alternators kick in and out at high frequency, as all five try to keep the voltage at spec. It wouldn't be the kind of thing I'd want to do haphazardly. You should also be aware that most alternators are rated at a current at some RPM. So that 5.5 kw your after, will probably only be attainable at 4-5k RPM (if your going with the ratings). The biggest alternators i've seen are 200 amp at 12v. which is around 2400 watt. |
Thanks for your answers!
This site sell dual, triple and quad alternators mounting kits. They also have a 315amps alternator. But how can all these power could be feed into the batteries?
http://nationsautoelectric.com/gmtriplet.html |
I think multi-alternator is semi-common among car audio peeps.
So long as it's designed to be run in parallel you'd be fine. They would probably have a single controller and load them all up in parallel. I didn't know they made such a system!
Nice find. |
Couldn't one be in the normal circuit and the rest be used solely to charge the auxiliary battery pack?
I think as long as you have only one external regulator hooked to multiple alternators field terminals it would work fine. That way each alternator increases its output the same, provided they are exactly the same alternator and have the same pulley.
This company do it this way :
This system would comprise three of our SR200.12 Power Generators ($675 ea.), one WC.12B Master Control Module ($195), two WC.12S Slave Control Modules ($165 ea.), and one WC.VR2 Voltage Regulator Module ($190). The three generators would be mounted so as to be driven by a single engine (though multiple engines can be used) -- typically be means of a single serpentine belt pulley mounted to the engine's drive shaft. The individual output terminals of the three generators would be connected together and with our electronic controls perform as a single generator (though more efficiently since we produce much less waste heat during the generation process. The total cost of the system would be $2740 Is there any way to do that cheaper? |
