EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Constant 12+ amps to SuperMID, yet shuts off (https://ecomodder.com/forum/showthread.php/constant-12-amps-supermid-yet-shuts-off-21571.html)
Cd 04-22-2012 01:12 PM
I wired my SuperMID to a prong on the fuse box that is showing a constant 12+ amps even with the key out of the ignition.
However, the SuperMID works only with the key in the ignition.
I used to have the SuperMID hooked up to where it would stay on at all times. ( at night the lit screen would stay on even with the key out . ) I can't recall where I had it hooked in before .
What have I done wrong, because the SuperMID seems to work, yet it shuts down as I shut off the car.
I tried to wire in with the radio, but I must have the wrong wire, because I have to turn the key on to get current.
The radio needs the key to function anyways, so I thought I would try the fuse route.
NachtRitter 04-22-2012 01:41 PM
I'm hoping you mean 12 volts?
Cd 04-22-2012 02:13 PM
Uhhhhhh . 12volts, 12 amps, 12 megawatts ....all the same right ?
Mods could you please delete this thread as well as my others related to the SuperMID* ?
I found the problem anyways ( pretty sure I had the VSS in place of the power wire. ) and its cluttering up the forum.
( * Or just keep it for laughs )
