EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Consumption at idle (https://ecomodder.com/forum/showthread.php/consumption-idle-6549.html)
groar 12-27-2008 05:03 AM
Consumption at idle
I had to try a Renault Twingo during one day [1] :
  • diesel 1.461L 65hp
  • manual 5sp
  • 3 doors
  • rated 45.2 (city) 61.9 (highway) 54.7 (combined)
  • CO2 113 g/km.
I plugged my SG2, which is incompatible with my 2 older Renault, and it was nearly fully compatible. It was missing TPS so the SG2 didn't had the open/closed loop information...
As I didn't know the cubic capacity when I plugged the SG2, I configured 1.6L, so the following figures are what I remember multiplied by 1.461/1.6.
I didn't had time this day so I have only been able to test the information I do not have in my scenic : the instantaneous consumption at speeds under 35km/h (21mph).
When the engine was started, the consumption at idle was at 1.65L/h (0.43gph). Ten seconds after it was down to 0.9L/h (0.24gph). After 1/4h of stop&go traffic, the consumption at idle stabilized at 0.73L/h (0.19gph).
Another thing I wanted to know is how much consumption the car has when you drive in 1st/2nd gear with the engine at idle (ie you doesn't touch any pedal). The results were :
gearL/100km/hmpgmph
1st18812.95
2nd91525.89
At these speeds, coasting in neutral would consume at 0.73L/h (0.19gph) :
km/hL/100mphmpg
89526
155948
The conclusion is that at low speeds it's certainly better to pulse 'n coast in neutral than keeping the engine in gear at idle rpm.
[1] the megane had a leak near the water pump, the thermostat melted in part and the temperature gauge was shifted down. As I didn't drive this car since months I though the low temperature shown by the gauge was because of near freezing temperatures and short commutes (20 miles). I worried when i saw the gauge going up & down... I had then not enough water in the cooling system. Happily it wasn't the water pump, but the water tank and a pipe.
Even without front grill (removed because this problem) and heating system at full load (in the hope to remove as much heat from under the hood) I achieved 43mpg, only 10% under my summer tanks :)
Denis.
FastPlastic 12-27-2008 01:05 PM
Good find!
Must be nice. Mine is in the range of .69gph at idle. Which I think is the main reason most SUV's get junk for gas mileage.
i_am_socket 12-29-2008 11:10 AM
In the few minutes my MPGuino was working yesterday, even not-quite-calibrated, I noticed that with the car not moving at idle it would consume less gas in neutral than drive. (.43 gph in drive, .35 gph in neutral)
binarycortex 01-08-2009 08:25 PM
I have a 98 vw new beetle 2.0L gas 4cyl. it is around 0.28gph at idle which is 810rpm ish.
cfg83 01-09-2009 03:23 AM
groar -
Cool! I love the first-gen Twingo design. The cute name totally fits the car's looks. Wow, 65HP is only 5 more HP than my Dad's 1971 Karmann Ghia.
My 1.9L engine shows about 0.3 GPH at idle (under 1000 RPM).
CarloSW2
holypaulie 01-09-2009 04:08 PM
My Civic' 03 1.7L fully warmed shows 0.2 GPH at 750 RPM.
taco 01-13-2009 11:57 PM
i get .35 in my 98 taco(2.7l) at 650-700 rpm (when warmed)
it would blow my mind to see .1gph
mobilerik 01-14-2009 12:40 AM
My Tacoma gets the same. (As it should.) Though when I coast in neutral on the highway, I get .44 sometimes. Maybe all the time... I need to check more often. Does yours do that? Why would that happen?
cfg83 01-14-2009 03:04 AM
akashic -
Is the idle RPM also higher? My "idle RPM in neutral" will be higher at freeway speeds. I think it is something the ECU/PCM does.
CarloSW2
taco 01-14-2009 04:17 AM
Yea I get .45gph at coast even with my 5 speed.
a
groar 01-14-2009 05:50 AM
I don't have the gph display, only the mpg and mph so I can easily calculate it. What I remarked is that the mpg display decreases more or less quickly depending on the temperatures, but also the consumption when I change to neutral. If I was accelerating quickly then it takes a lot of time to decrease to the stable idle consumption.
Now when I put in neutral while I was in engine break (DFCO) then the consumption increases to the stable idle consumption. I'm wondering if the strategy can save gas, but I doubt about it as you have to accelerate to a greater speed and loose noticeable speed during the 2 seconds of engine break needed to reach DFCO.
Denis.
AcN 01-16-2009 04:08 AM
Crazy analysis Denis, thanks a lot ;)
Should get a SG2 someday for my hyundai, or maybe i should just locate the OBDII port before.
Weird the 97 and 01 Renault don't work with it... by the way, what was them problem with that ?
groar 01-17-2009 07:12 AM
Wanted to know such data since a long time as my iMPG (instantaneous) display in scenic doesn't show any value under 35km/h (22mph) and I'm often blocked in (very) slow traffic.
From ScanTool.net LLC - Powered By Kayako eSupport I found this : OBD Clearinghouse
The looong story : http://ecomodder.com/forum/showthrea...ault-4527.html
My cars are European so EOBD (European name for OBD2) is mandatory for gasoline since 2001 and for diesel since 2004. Both my cars are diesel.
Denis.
