Old 02-15-2010, 07:20 AM   This thread is in the EcoModder Project Library | #1 (permalink)
recession proof rebel
k.civic.f4i's Avatar
92-95 civic passenger mirror delete how to
this is a "how to" on creating a mirror delete from an old broken passenger mirror.
required:
-broken passenger mirror(free from the junkyard)
-tape of some sort (painters tape preferable)
-small can of bondo (smallest can)
-small can of fiberglass resin (smallest can)
-sandpaper (80 grit, 320 grit, one page of each)
-high build primer
-flat black spray paint( i prefer the finish of krylon)
suggested:
-latex gloves
-mask
-eye protection
-hand-sized block sander
-bondo spreader
first break and grind off the remains of what once held a mirror. safety first. protect your eyes and fingers. try to cut/grind it as flush as possible here. for some reason honda decided to use a porcelain material for their oem mirror bases. yours may be plastic(so much easier).
tape off the holes you created and try to make this look as close to the finished shape as possible. FLUSH
next turn it over, mix some resin with the provided hardener and pour into the holes
let it harden and peel off the tape. you should have something like this:
now take some 80 grit sand paper and sand it down. a hand-sized block sander is helpful. everywhere you plan on applying bondo should look like this in order for it to grab the material:
apply a thin layer of bondo.
sand down big imperfections with the 80 grit you used earlier to get the basic shape. after the big imperfections are gone use the 320 grit to get it perfect for the primer.
go over this again with a THIN layer of bondo if you can feel any imperfections that can't be corrected by more sanding(low spots).
apply primer using thin even coats. the high build primer is used to fill in the teeth left by the sand paper. i used 2 layer of primer. you may only need to apply 1 layer depending on the quality of primer you bought. make sure to cover all of the bondo.
spray the final coat of paint using thin even coats. spray at somewhat of a distance to avoid drips. if you do get drips sand the entire piece with 600 grit and respray.
viola. and mounted
critiques, advice and thoughts please
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
The Following 5 Users Say Thank You to k.civic.f4i For This Useful Post:
California98Civic (03-31-2011), Cd (02-17-2010), Christ (02-16-2010), Fr3AkAzOiD (09-07-2010), NachtRitter (02-18-2010)
Old 02-15-2010, 10:05 AM   #2 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Nicely done
Old 02-15-2010, 06:12 PM   #3 (permalink)
its really not that much work. just attention to detail when you're doing it
how to.....
Old 02-15-2010, 09:45 PM   #4 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
Nice work there! Looks good and factory.
Old 02-16-2010, 12:34 AM   #5 (permalink)
my goal with all my mods is to have a car i can still bare to look at and still be able to reap aerodynamic benefits. so basically= stock/natural looking but still aerodynamic
i want you to have to actually LOOK to be able to see the mods.
how to.....
Old 02-16-2010, 12:53 AM   #6 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Nice job, Kris.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 02-17-2010, 07:51 PM   #7 (permalink)
Daq Civic - '92 Honda Civic DX sedan
90 day: 42.54 mpg (US)
The Hardbody - '91 Nissan D21 (pickup)
k.civic, can I ask what it looks like when you start grinding away at the arm that holds the mirror? Would it be possible to reduce the profile of the arm itself while keeping the mirror attached?
Old 02-18-2010, 08:20 PM   #8 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
I just managed to get hold of a broken mirror with plans to do this very same thing, so your post is very timely... thank you!
Old 02-20-2010, 02:24 AM   #9 (permalink)
daqcivic: im not sure if im understanding your questions correctly. but from what i am understanding, id have to say no. the mechanism that allows the mirror to move is tightly packed in there, so i dont think youd be able to chop up the mirror without destroying it entirely.
NachtRitter: were you able to obtain a broken plastic mirror or did you get the oem one with the porcelain-like base? the plastic one wouldve been way easier to work with. you're relatively close. maybe we can meet up some time. ive never checked out a vx in person
how to.....
Old 02-20-2010, 02:31 AM   #10 (permalink)
daqcivic: the arm and base are made out of that porcelain/cement-ish material. it's solid. the mirror housing was the only plastic on the one i worked on(O.E.M.). it only has hollow chambers on the plate piece.
how to.....
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
92 Honda Civic VX for Sale in Toronto area bt10 For Sale 0 01-19-2010 09:55 PM
CNET: your '92 Civic may get far better MPG than a new car, but it still sucks! MetroMPG General Efficiency Discussion 48 06-23-2009 11:18 AM
New member, buying a 92 Civic DX, looking for opinions... exo General Efficiency Discussion 7 06-02-2009 02:06 PM
95 Civic VX Daox For Sale 8 04-17-2009 10:21 PM
