Old 09-28-2010, 06:28 PM   #1 (permalink)
2000 Dakota aux fan problem
I have a 2000 Dodge Dakota, V8. The lower fan, I assume that it's the auxillary fan, stayed on after shutting the truck off after a 30 minute ride in 80 degree weather with the AC on. It ran for 30 minutes until I disconnected the battery. After about a minute, I reconnected the batter and it came back on. I disconnected the battery again and let it sit overnight. The next morning everything seemed fine. Any ideas what might be the problem?
Thanks
Andy
Old 09-29-2010, 11:46 AM   #2 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
My 2 cents, look for a loose wire or corroded connection. it sounds like the fan forgot that the key was turned off and kept running until the temp was down.
LED indicator help Chalupa102 EcoModding Central 17 05-08-2014 01:25 AM
Electric vs. belt driven cooling fan Gregte EcoModding Central 63 06-18-2013 06:42 AM
Fan tool (special tool for fan removal) GasGuage DIY / How-to 5 01-01-2009 01:47 PM
S10 radiator fan changes? bennelson EcoModding Central 29 12-29-2008 07:54 PM
