Cool new MPGuino display!
After over a month of working over the original dcb MPGuino code, I started adding things to it myself.
One of these things is this: http://ecomodder.com/forum/attachmen...1&d=1380230137 This picture was taken after I commuted into work today. It shows the characteristic fuel economy curve as a function of vehicle speed. Each segment represents a 6 MPH band. Considering that I wrote the code that generated that, about two hours before I started into work, that picture's pretty awesome. I hope to be able to add the below function (like the ScanGauge E) in the next day or so. (it's in there now, but it does not work at all, for some reason). I also hope to be able to make the above screen a little more user-friendly. http://ecomodder.com/forum/attachmen...1&d=1380230536 |
I use a UG, but that's pretty slick, should be easier to discern at a glance.
