Coolant heater *failed*
Well, the other night I was out late, got home around 10pm. Had to be up for work at 4:45am, but I REALLY wanted a toasty car to get into, so I stayed up to midnight to install my heater (Kats 1500w aluminum tank).
I got it in and refilled the lost coolant, ran the engine for a few to burp it, topped it off. Plugged the heater in. It got hot. The hoses around it got hot. I thought "success!" and went in and got a short 4 hours of sleep. Went back out to go to work and its DEAD. Nothing, freezing cold. Its the heater too, the circuit aint blown. I plugged a light in and its fine. The stupid things a dud. Or is it? Anyone had similar experiences? I can ask for a return from amazon right now but if theres any hope of it working I would like it *now* lol. |
sounds cooked to me. Try another outlet to be sure.
Rule out the heater cord itself. I think that's more likely to fail than the heater element, assuming it was surrounded by coolant, and the coolant was flowing.
Tried a couple outlets, the cord looks fine. Not sure how else to check other than take the heater apart, and I want to be able to send it back.
I sent for a replacement. |
Try putting a multimeter on it to measure the resistance. I'll go do mine right now and you can compare...
OK, I'm back! Man it's cold out. :D I read 16.4 ohms at the plugs/prongs of the heater cord. Which is roughly what is should be, according to this calculator: Enter 110 volts, 16.4 ohms and hit "calculate" = 737 watts. @ 115v = 806 Watts. Mine's a 800w nominal heater. Ohms Law Calculator |
Took the meter to it, it read nothing except for very very brief instances, and then it read something like 191.2 ohms which calculates to like 63 watts.
Dud. |
