EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   coroplast fabricating tips/guide (https://ecomodder.com/forum/showthread.php/coroplast-fabricating-tips-guide-36023.html)
seifrob 01-07-2018 02:46 PM
I did not find this webpage reference in the forum so I am posting it: https://www.christinedemerchant.com/...ng-gluing.html.
If you have any other tips, feel free to add them.
Daschicken 01-07-2018 11:26 PM
That's a good tip for gluing/taping with coroplast. The velcro I use to hold on my grille block has never been confidence inspiring, so I guess I could use heat first.
I actually have to use a heat gun on stick-on wheel weights at work when its cold, so I probably should have thought of this before.
Grant-53 01-08-2018 10:59 AM
Clamps help hold pieces in place while I poke holes with an awl 8-12 mm apart for zip ties. I typically use white Gorilla tape on the seam. To paint, after prep apply two light coats to avoid cracking. Some automotive paints have a flex additive for bumpers.
freebeard 01-08-2018 02:32 PM
Reinforced edge:
http://ecomodder.com/forum/member-fr...12-1-55-49.png
Raw edge
Recessed by d/2 to be wrapped by tape
Recessed by 2d to be folded and wrapped with tape
This is theory, let me know if it works. :)
Daox 01-08-2018 04:30 PM
Great article. Thanks for posting.
