Old 09-25-2008, 05:27 PM   #1 (permalink)
Matt Herring's Avatar
Bone's 2010 Prius - '10 Toyota Prius Black
90 day: 56.78 mpg (US)
Random Thought of the Day
While parking my car today in a big lot with several available spaces I had a random thought and wanted to see if it holds any water (even a smidgen of truth will convince me I haven't gone totally bonkers).
When driving in reverse (i.e. backing out of a parking space ordriveway) does the odometer actually run backwards and decrease in total mileage (even .001 of a mile when you backup)?
And if the odometer does run backwards would it be beneficial to MPG to always park so your car can pull forward out of a parking space rather than backing out of a parking space (even if it saves .001 of a mile when you pull forward out of the space)?
Alot of times in big parking lots you can pull into a space and go through that space into another space (allowing your car to pull out forward the next time you get in).
Obviously, I would not expect any substantial MPG savings if this is true but when random questions arise then random answers are needed.
Welcome to my brain after working an 18 hour shift!
Old 09-25-2008, 06:29 PM   #2 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
The answer my Friend is
It depends.
I have not worked on a car, ever, that ran the Odo backward.
Newer cars, 1996 & up usually, the Odo runs forward all the time. Even when you back up.
Try backing down your street in the middle of the night sometime. You will see that the Speedo registers road speed and the Odo goes up .1 mile.
Older cars, cable and gear driven stuff, the Odo stops and the Speedo stop when you reverse.
No loss of miles but no gain either.
You are not crazy.
I am sure others were waiting for you to ask.
Schultz.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
Old 09-25-2008, 11:31 PM   #3 (permalink)
In any case, it wouldn't change your actual mpg at all, just add another bit of inaccuracy to the computation.
Old 09-26-2008, 10:18 AM   #4 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Regardless of what the odometer does, you'll find that "pull-through" parking (vs. reversing out) is recommended in the 100+ Hypermiling Tips .
Old 09-26-2008, 11:33 AM   #5 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Didn't anybody see Ferris Bueller's Day Off?
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 09-26-2008, 11:38 AM   #6 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
That's exactly what I was going to say!
Old 09-26-2008, 11:42 AM   #7 (permalink)
Kawi - '04 Kawasaki Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Chevrolet Monte Carlo Z34
90 day: 26.52 mpg (US)
Mazda - '10 Mazda 3i
90 day: 35.15 mpg (US)
I did see Ferris Bueller's Day Off, and unfortunately the movie is accurate, miles will not come off the od without you actually messing with the od and rolling it back yourself. Which is not recommended. But backing out of a parking spot is not recommended simply because you use more gas to back up and then drive forward than you would if you just pulled out of a spot.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
4 Day School Weeks To Save Fuel Matt Herring EcoModding Central 9 07-25-2008 03:12 PM
ABG's ebay find of the day SVOboy Fossil Fuel Free 3 07-17-2008 05:21 PM
Atlanta Clean Air day NoCO2 Alternative Transportation 0 06-10-2008 12:25 PM
Random thought reguarding ICE off/MPG figures Chris D. EcoModding Central 8 04-28-2008 10:25 AM
Valentines Day is Upon Us! metroschultz The Lounge 1 02-14-2008 03:36 PM
