corvair aeromods
There are some bueatiful cars on this site. This car has extensive cooling re-engineering. I'm most interested it the purpose of the sill skirts.
http://www.corvaircorsa.com/evans04.html |
Those are what I've been calling side skirts. I've written elsewhere on the site about their potential benefits (as I see them). Don't mean to be lazy by quoting myself, but why repeat? :p
This explanation wouldn't really apply to those skirts as they aren't extensive enough, nor is its underside built up to maximize their benefits. From the thread "Win $100" Quote:
I missed that explanation in the contest thread. Thorough.
I wonder if the benefits outlined would exceed the increase in apparent frontal area in cross-wind conditions. Considering that we probably spend more time experiencing cross winds than not, it's an important question. |
Just when I thought I had a plan for Sven's underbelly LostCause has re-educated me. Or perhaps just partially educated me, first time.
I thought I'd make a belly pan flush with the lower edge of side skirts yet to be built. However that would eliminate the "directional" effect of the side skirts that LostCause described. Am I understanding things correctly now? |
Good point about the crosswind issue. The first thing that comes to mind is that the car only experiences apparent velocity (like sailboats' "apparent wind"). The total component is what matters and unless it is really blowing outside or vehicle speed is slow (<45mph), then I'd imagine the wind angle would be pretty shallow. You are right though, it deserves attention.
I've taken the directional benefit from a section I came across in Hucho's book. Everything I write is from memory...and my mind is like a sieve. :p Quote:
http://i264.photobucket.com/albums/i...d1961gyron.jpg - LostCause |
Colibra and Porsche Carrrera GT have skirts in the horizontal plane, almost perpendicular to the sides of the car.
I suppose this is to fair the air that flows obliquely out from under the car, easing its exit, but somewhat fencing off side gusts so they don't go under the car. Sort of a crude flow valve, where air flows more easily out than in. Perhaps it also fairs and smoothens the flow from the wake of the front wheels. Your thoughts? |
