EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   corvette/firebird style engine cooling (https://ecomodder.com/forum/showthread.php/corvette-firebird-style-engine-cooling-12272.html)
moonmonkey 02-11-2010 10:30 PM
would an air intake system (engine cooling) like a corvette's bring less drag than leaving a small area open on the lower grill, on a dual grill car like an echo/corolla..corvettes have an area under the front of the car that sticks down into the airflow about 2-3" down and about as wide as the radiator and a curved air diverter, allowing the hood/bumper area to be completly sealed. this "air catcher" is about 12" behind the front bumper, my measurements my be off a little, as i did not want to explain to the corvette owner why i was under his car. my upper grill is already completly blocked, and my lower is partialy blocked,,tring to decide on corvette style vs. an active lower grillblock ,ideas?
MetroMPG 02-12-2010 01:38 PM
Not familiar with the style. Maybe post a photo (even something from Google images)?
ChillyBear 02-12-2010 01:55 PM
think of an air dam that connects to the bottom of the radiator. This forces the air into the fins.
Sgt_K 02-12-2010 02:07 PM
Yup, they are called "bottom feeders" because the air is pushed up from the bottom of the car by the lower air dam. It makes a lot of sense because you get the benefit of the air dam cleaning up the bottom of the car, aerodynamically speaking, and you don't have a gigantic grill opening on the front grill of the car.
brucey 02-12-2010 02:58 PM
http://image.vetteweb.com/f/27151413...engine_bay.jpg
You can get an idea of whats going on there.
The opening on the front bumper seems to be for the engine only.
aerohead 02-13-2010 03:45 PM
aero mod sticky
I think I put the Trans Am data in the mod data sticky here at the aero forum.It should have the number you're looking for.
Rokeby 02-13-2010 04:55 PM
Pictures of this arrangement in this past thread. A little more here.
These pictures show how cooling air is directed to the radiator.
I haven't found pictures of what special arrangements if any are made to lead
the air out of the engine bay and under the car -- something like the BMW
gently radiused ducting perhaps?
