The Cost of Learning (aeromodding a Toyota pickup)
Ok, so I've been a Ecomodder lurker for some time now an all I have really done is adjust the nut behind the wheel. now I'm commuting to and from college (15 miles twice a day) four days a week an my budget is tight... Fine I'm cheap an I've been thinking about a few mods for my vehicle a Toyota Pickup, 4 cylinder, 5 speed. Its my baby! :turtle: I've gotten up to 30 Mpg highway on long trips, but back to mods. I know that the most beneficial mods are in the back like a aero bed cover, an boat tails. but they are not in the budget right now. So I've been thinking I should try a set of rear wheel skirts an track my tank to tank mpg to see improvements. What should I make them out of? how should I attach them? I've been thinking I should make a cardboard prototype an use duct-tape. But I'm also concerned about looks too, so I was thinking of painting, but if I'm going to do that why not do it right... Right? :confused:
I learned a lot from using the search feature and looking at how other people had made theirs. Other than that, I just attacked it and figured it out as I went along. |
I don't have any election signs that I can get my hands on, but I do have a lot of cardboard an thin wood strips that I can use to make up a sturdy design. thinking a coat of paint and poly would seal the deal an keep water out while looking good. I may be able to rig something up so I can secure bolts on my skirts an just use a wing nut or something of the sort so it has an easy on/off capability. Thanks for the ideas, I'll look into materials tomorrow since I have only one class tomorrow. Seems like a waste driving down for just an hour an a half class, but it is what it is.
Speaking of which: an actual tonneau cover isn't as good as an aero cap , but better than an open bed. Also easy to make with scrounged materials, and should meet with dad's blind spot approval.
glass
Residential window glass might get you in trouble. Keep your eye out for some sort of Plexiglass/Lexan for the peep hole,as they're both certified as replacement DOT glazing. I've used discarded skylights which had a defect and just cut good material out. If you put masking tape on the plastic,mark your lines and cut,you won't scratch the material.A sabre saw or bandsaw works great. |
Second to what aerohead said.
I get cut-offs from the local hippy recyclers. for instance triangles of 1/8" ABS 42" on the short sides (US$4ea). If I could find an old satellite dish to use for a slump mold, that would be great. If you had the dish, you could just cut that up. Or you could drill a hole in a disk of aluminum sheet, chuck it up and spin it in an improvised English wheel, or clay on a potters wheel. It would make something like a big Moon disk with a hole in the center. Then cut it in half and trim each half to the shape of your wheel well. |
I know its been a while since I have posted anything to the thread, but due to the cold weather I've been getting about 23 out of my truck and it hurts after seeing 26 in the warmer months. So that pushed me to buy materials for a tonneau cover, two sheets of 7/16 OSB, and various washers, nuts, screws, and bolts. I plan for it to be removable, and light but strong enough (may have to put ribs on the underside) to withstand the wind. also saving a few bucks and having some fun with this project I plan on forging my own "L" brackets to secure the cover.
Have you done a grill block? Thats a great place to start for aero and warm up (especially in winter)
I've ran a goofy lookin cardboard one on my truck for a trip but nothing serious yet. Still haven't decided what to go for, either pipe insulation or coroplast. could just block the radiator with cardboard did that last year when I didn't keep track of MPG.
Blocking the radiator alone is OK for warm-up, but may not help much with aero, since you've permitted air into the "aerodynamically dirty" path to the engine compartment.
The goal is to only allow in as much as you need for cooling, and send the rest around the vehicle, where the aero penalty is lower. |
Oriented Strand Board should be thoroughly waterproofed.
1 Attachment(s)
Ok, so I got the cover all cut out and spent last night working on making it fit right. The cover is pretty simple just two 60"x37.5" sections making a 60"x75" cover that folds in half and is able to be picked up by one person and fits between the wheel wells if I need to haul anything. I put one coat of poly on it and once it dries I'm going to paint it to match the truck and put a racing stripe down it for looks. :turtle:
4 Attachment(s)
So I have been working on my tonneau cover for the past three days. I put a coat of poly on, two coats of red paint an the black racing stripes, now all that is left is the last coat of poly. I finally took some pictures this time and I think the cover looks rather nice. I'd like some opinions on how the cover tuned out. do you think it will improve aero vs an open bed? I may add a kam to the truck cab so I can improve aero a little more but I cant block too much or I cant see, and I don want to go full aero shell (yet).
Definitely will help with aero vs. an open bed. That's well understood.
Counter-intuitively, a "half tonneau" would be even better, though arguably more difficult to make, plus utility goes down. Search the site for that if you're interested. |
aero
So maybe 2.8-3.5% better mpg on the highway.More the faster you drive. |
4%
*A little better with a blister http://i1271.photobucket.com/albums/...ohead2/201.jpg *A crude wing/sail panel added gets some extra mpg http://i1271.photobucket.com/albums/...ohead2/206.jpg There are a bunch of varieties and combinations,even inflated tails http://i1271.photobucket.com/albums/...ohead2/208.jpg |
I'm going to have to try the wing/sail and half tonneau combo in the next tank or so. I kinda like the looks of it. But before I do anything else I should go for the grille block and finish my rear wheel skirts. (The frames have been sitting around for a few months)
I know you have it already made and painted, but I see tonneaus on craigslist by the handful every time I check. Pretty cheap too. I got one for $100. I see 'trifold' models too, which might allow a partial tonneau effect to be achieved.
As for their effectiveness relating to fuel efficiency; I must admit that my experience has been that it has little to no effect. I do a fair bit of highway driving, which is where gains should be seen, but I'm not seeing them. The best thing I can say about my tonneau experience is that it keeps all of the crap in the bed from blowing into the cab when I open the sliding rear window. :o :( |
Sounds like a well designed cover! Cheap too. ;) I'll be interested to see if you notice mileage improvement.
For the OP: I'm surprised you're only getting ~23 mpg out of your truck. From the picture, it looks like a 2WD, no? But I get around 26 from my '88 4WD, and that's including a lot of load hauling & driving up rough mountain dirt roads. |
An Merry Christmas to those of you that celebrate it and Happy holidays to everyone. |
Oriented Strand Board is not fit for purpose. But since you're at the 'plenty of money to fix it later' stage—compare the costs involved for your 'poly' product and a quart of Plastidip and a disposable roller.
It was prescient to title the thread 'The Cost of Learning'.
I looked back but it's hard to tell from your pictures whether there were any pieces bolted together before painting (framing, etc.). If there were, they should have been painted before assembly so the poly (polyurethane?) didn't need to bridge the gap. Location of the damage may reveal something. What do you think about Plastidip? You could use up the poly on the worst spots, then 4 or 5 spray coats or 1 or 2 rolled coats of Plastidip would make a rubberized coating that would seal everything together. It needs to cure 30-60 day, then it will be more or less immune to nicks and tears. |
So it's been a while since I've worked on the bed cover, it's been too cold to put more coats of poly on the past month or so. :( But recently there have been a few 45* days an I put an extra heavy coat on the two pieces of the bed cover. So now it's back on the truck. Hopefully it will hold together and show some mpg improvements. :turtle:
