Old 03-11-2016, 05:20 AM   #1 (permalink)
Silver Magnum - '03 Dodge Ram 1500 Laramie
90 day: 11.43 mpg (US)
E fan conversion.
Looking to convert to an E fan for space savings and hopefully one or two more mpg if I'm lucky.
Can someone point me in a direction to start? I would like to have enough cooling ability to keep the engine at 180 degrees at idle in summer. Manual switch would be nice if possible. Thanks!
Old 03-11-2016, 08:58 AM   #2 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
First thing I'd look for is if newer Rams have E-fans. It's a popular and easy swap in Chevy trucks. Look to see if your computer has the ability to activate a fan too, it might just need a tune and a wire added to the harness off the computer. Manual control is a concern it case you aren't paying attention in traffic, someone borrows your truck or other unforeseen circumstances. The truck engine in my car had the spot for a relay ground to activate the cooling fan, I can change turn on/off temps in the tune using HPTuners.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 03-11-2016, 09:50 AM   #3 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
I would check out a Ram forum and see what others have done with the same truck. It's a fairly common mod for trucks; the belt driven fan takes a few ponies to spin so it frees up some power.
Camry Thread
E-Bike Thread
Old 03-11-2016, 03:44 PM   #4 (permalink)
Even if the ECU eventually doesn't have the ability to control a fan, it's still viable to just use a thermostat to kick it in. And it wouldn't prevent the fitment of a bypass switch.
Old 03-11-2016, 07:36 PM   #5 (permalink)
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Here is my writeup from when I put an electric fans in my 2005 Tacoma. The cost/effort was higher than most swaps, but I was not trilled with the reliability of most aftermarket controllers.
http://ecomodder.com/forum/showthrea...ler-32368.html
Old 03-11-2016, 08:08 PM   #6 (permalink)
Primer is still paint!
ChopStix's Avatar
I bought my E fan conversion off ebay for $51 USD. The 16 inch fan was $26 w/free shipping and the thermostat was $25 w/free shipping. The thermostat is temp adjustable. So all you do is throw it on the vehicle and dial it in to turn on/off at whatever temp setting you set. Then you can wire a switch to manually turn it on/off if you choose.
My plan is slightly different than what you said. I'm considering adding a second fan in front of my radiator with only a manual switch for when I pull my trailer with the AC on. In that situation I would just leave it on the whole time. But the main fan behind the radiator will only be run automatically switched by the thermostat, no manual switch.
Here's my build thread for my van
Old 03-11-2016, 09:32 PM   #7 (permalink)
A 1 to 3mpg improvement is typical for a truck or SUV.
Old 03-11-2016, 10:15 PM   #8 (permalink)
1 to 3 mpg would be wonderful but I already gained 7 so that would honestly blow me away if I can exceed 20 with this level of power.
Thanks for all the build guides, looking them over and I think I will try to do the electronically controlled route so I don't have to keep messing with a switch.
