Crank pulley removal
So I'm trying to get my crank pulley off and so far I've accomplished the following:
1) Wear myself out 2) Bend the hell out of my biggest screwdriver 3) Nearly break my 3/8 rachet. And still the crank pulley remains firmly attached to the car. I have been attempting to hold the pulley still with my big screwdriver (jammed into one of the holes, holding against the oilpan flange) Meanwhile a helper applies force to the crankshaft pulley bolt using my 3/8 rachet and a 2' cheater bar. Once force is applied, I tap on it with a hammer. (cheap impact driver) So, does anyone else have any suggestions for me? I'll probably end up buying a 1/2 breaker bar tomorrow. But I'd really like to avoid having to rent a impact wrench and air compressor. |
Without immobilizing the crank about the only way to do it is with a strong impact gun. They're never in there anything beyond "OMG THIS IS HARD TO GET OFF!" which is some ungodly amount of ft lbs. I had to use a strong impact gun to get mine out. You're taking it off ENTIRELY? Are you taking off alternator/powersteering/ac entirely too?
Air powered impact is the only way to win. It also helps to put a small amount of silicone on the bolt when re-installing it to prevent any oil leakage.
I'm almost contemplating driving it to a shop to have that one stinkin' bolt removed. It's not like I even need the crank pulley to drive it back home (I am running the alternator beltless after all) |
Johnny is right on. An impact is pretty much necessary. If you don't have access to an air compressor electric impacts work alright too. Maybe they rent them locally?
An impact gun is the only way I've seen them come off
I'm lucky my local garage has been pretty good about stuff like this - I've dropped by once or twice with uncooperative nuts/bolts and they've run the air hose out and freed it for me on the spot. Must be my puppy dog eyes.
Yes! An electric impact would also do the job!
don't drive it with the bolt out, if that pulley moves and the timing belt jumps you have bent valves on your hands.
I have replaced a few Honda heads in my time, pretty easy but when your paying it costs money :eek: and yeah as johnny said I have only seen those come off with an impact gun |
Impact, or a BIG breaker bar. I've done em on 2 Toyota trucks with a large 1/2" breaker bar and a 3 foot cheater pipe. Hard to get enough room to swing the whole thing though. 200+ ft-lbs plus Michigan rust equals "damn that's tough!".
