Old 12-03-2007, 08:59 PM   #1 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
Article: Tips tested by Edmunds
Here's some testing that shows some fairly realistic results. I think the tire pressure should be given a little more weight but all in all I think they did a fair job. I think a 50% increase over current MPG is easily achievable by driver techniques only for those just getting into the ECO game.
"Judge a person by their questions rather than their answers."
The Following User Says Thank You to Lazarus For This Useful Post:
101Volts (09-03-2013)
Old 12-03-2007, 09:54 PM   #2 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I agree, I consistently see an appreciable improvement in Fuel Economy by just bumping up the TP to the manufacturers max or 50 psi. This, honestly, should be one of the first and easiest mods for new EcoModders...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
The Following User Says Thank You to RH77 For This Useful Post:
Old 12-03-2007, 10:10 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I plan a simple experiment on this. It's one of the few ones I can do in the winter.
And the effects of low pressure are even worse in winter, since the rubber compound stiffens in the cold.
Old 09-03-2013, 03:20 PM   #4 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 17.09 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
The page is gone. What was there?
Last edited by 101Volts; 09-18-2013 at 07:55 PM.. Reason: I changed a comma to a period
