EcoModder.com
-   -   CRX front drum brake conversion (https://ecomodder.com/forum/showthread.php/crx-front-drum-brake-conversion-19185.html)
jrnsr 10-18-2011 12:40 AM
Does anyone have some insight into parts interchange for front brake conversion to drum?
I'm setting up a 750cc CRX for high fuel mileage and drum brakes offer lower resistance.
'88 CRX DX
3gd16 10-18-2011 01:10 PM
Never heard it beeing done before but give it a try. You may need to fabb alot
arcosine 10-18-2011 01:41 PM
I think the HF model front disks are low drag.
Ryland 10-18-2011 09:32 PM
You would have an easier time putting first gen Honda Insight front brakes on, the drum brakes are not set up for live axles unless you go back to a 1984 to 1991 Honda Wagovan with 4 wheel drive, but it's hard to say if those would even work.
Issue is, drum brakes tend to grab more and are more likely to lock up then disk brakes so your braking is not going to be nearly as smooth nor safe and cars that crash don't save you anything.
Frank Lee 10-18-2011 09:47 PM
Oh please. I have several cars with 4 wheel drums and they are no more likely to crash than the ones with discs. In fact they are no more likely to have any brake or braking related issues.
jrnsr 10-19-2011 12:32 AM
"the drum brakes are not set up for live axles unless you go back to a 1984 to 1991 Honda Wagovan with 4 wheel drive, but it's hard to say if those would even work."
That's the direction I wondered about but don't have first hand experience with the Wagovan rear. Hoping someone else "been there, done that." Thanks for the input.
Ryland 10-19-2011 01:41 AM
Thanks for putting us all at ease that retrofitting drum brakes designed for the rear of a vehicle on the front will not have any issues and should be just as safe!
I own cars as well with 4 wheel drum brakes and find them to be very grabby and touchy, I've also had motorcycles with front drums and the motorcycles with the best brake control had both shoes set up to expand pushing only the trailing edge in to the brake drum, the motorcycles that had harsh braking had front drums that were modeled after the simple design of the rear brake drums.
But back on topic, No, the rear drum brakes will not bolt on to the front steering knuckle, the drum would but the backing plate with the brake cylinder, return springs and brake shoes will not bolt on, if you have use of a milling machine you could make an adapter that bolts on to the two threaded holes where the caliper bolts go and then provide the 4 bolt holes needed for the brake backing plate, but I suspect that if you had to hire that task out you would never see a return on your investment.
Frank Lee 10-19-2011 02:49 AM
^Yup about the fitment. Nope about the dynamics and safety and whatnot.
I'd like to put drums on the fronts of my stuff but in addition to what Ryland said about adapters, I think getting the backing plate over the hub would be problematic as the hubs come off easily on the rear but not so on the front (at least on my stuff). That is solveable... next it is my understanding that master cylinders produce different volumes and pressures for the disc and drum circuits, so something would have to be done to make the front circuit suitable for the drums. Would proportioning valve(s) do it? I haven't really thought that part through.
So the path of least resistance (PUN!) might be to devise a working return spring arrangement for disk calipers. I understand some newer calipers have such a setup so maybe they could be adapted.
For me the path of even lesser resistance has been to maintain the stock system, trying to stay ahead of corrosion so that moving parts can move and seated parts don't unseat and parts that are supposed to contain fluid don't squirt it out all over.
jakobnev 10-19-2011 05:30 AM
Originally Posted by jrnsr (Post 266021)
..and drum brakes offer lower resistance.
Is there any chance you reached this (possibly false) conclusion by turning the wheels of your FWD, front disc, rear drum-car by hand?
Ryland 10-19-2011 09:57 AM
Of all the disk brakes out there that are going to give you the least number of issues and give you next to zero drag, the Honda Insight calipers should do the job, they are an aluminum caliper instead of cast iron (lower unsprung weight) and every part of that car has been designed for fuel economy and all it takes to make sure that you disk brakes are not draging is longer throw on the return springs so that you are assured to have a gap between the brake pad and the disk, if there is a gap then there is nothing to drag.
There are a lot of Honda Insight parts that might help you out, rear brake drums are aluminum with iron liners, I have a set on my civic vx and they are a perfect fit so they will fit the CRX as well saving around 3 pounds of unsprung rotating weight and if you want to get really nit picky, you can even get the aluminum wheel cylinders that the insight has, they cost a little more then the iron parts but they'll help cut your weight down even more.
jrnsr 10-19-2011 12:19 PM
Out of all the various forums I posted this question on, you guys are the only ones with intelligent responses. Most others just post stupid insults.
We used to have a carbureted '87 CRX, with the aluminum rear drums & superlight wheels, rated 57 mgp highway. We even ran it successfully on 2 cylinders, but it was a real slug.
Now, I'm setting up another CRX to run on 2 cylinders, but have the 2 center cylinders supercharge the outside cylinders (welding/grinding cam required). Fuel injection will be a vast improvement over the previous one with motorcycle carbs.
The idea of springs is on the right track, but there's no feedback/control to compensate for wear. Too much space will mandate pumping the brakes before they grip. Small springs would be a viable option for short term events. Most of us don't remember that the old mechanical brakes had to be adjusted constantly, so an adjustable spring idea is a viable option for only the most conscientious car owner. Maybe someday Japan will come out with an electric (electro hydraulic even) servo system to clear the pads from the disc, or even incorporate that into the ABS hardware that exists.
When I converted our '50 MG to front disc brakes, a proportioning & compensating valve was a pretty important addition, otherwise, the mismatched behavior between discs/drums leads to spinouts. The fact that disc drag and drum brakes don't is why the compensator valving was developed, to hold the calipers back until the shoes provide resistance. For a car with 4 drum brakes, no proportioning valve is needed.
Gasoline Fumes 10-19-2011 11:01 PM
The front brakes on my 1991 Civic Wagon don't drag. The pads actually rattle around in the caliper brackets with the brakes released. Keep everything in good shape and they won't drag. No mods required.
arcosine 10-20-2011 08:16 AM
I made a 800 cc honda accord, terribly slow, out accelerated by semi-trucks. mpg only 14% better than full 1600 cc engine. Consider putting in a HF transmission in the car first. With 165/80R15 tires on Saturn rims the RPM will be 1630 at 60 mph.
Ryland 10-20-2011 09:00 AM
The front brake calipers don't have return springs, they rely on the O-ring that seals the piston to return it as it has a square profile, if these O-rings are 30 years old they could be dried out and not working like they should, replacing them might give you the results that you are looking for.
The last time I checked my front brakes there were clear gaps between the pads and the disk and my disks are original to the car (220,000 miles) so they have had very little drag over their life time or they would have wore out by now.
The rest of your project sounds interesting, care to tell us more about it? maybe start another thread on the super charging project?
