CRX HF / Civic VX Catalytic Converter Q's - Possible Discovery
Okay after some research I've figured out that the HF's and the VX's both use the same Catalytic Converter and are available aftermarket at the tune of ~$250 (Part # EASTERN CATALYTIC 40352). Which is news to me,I was told no one had the HF converter available,let alone the VX/HF both share the same one..
Now to the good stuff,and I'm just pondering here.. It looks to me like a 96-00 Civic HX exhaust manifold/catalytic converter might work it sits in the same angle,and has the same bolt pattern to the down-pipe.. Which would mean much more parts availability and cheaper (can get complete manifold/converter for $160 shipped online,HF manifold is unavailable) parts for when the HF/VX one's eventually dry up.. Pic below of first a HF/VX one,followed by the next generation design. Thoughts? Anyone tried this yet? http://www.hondaautomotiveparts.com/.../SH23E0400.gif http://i.ebayimg.com/images/g/UAAAAO...7x/s-l1600.jpg |
Ah darn,realized that second bung on the bottom of the next gen converter is for another o2 sensor because they're OBD-2.. But if that was plugged,I still think it'd be worth it. Idk I learned something today though ^_^
Either plug it, or stick a o2 sensor in there to plug it, either way it really doesn't change that it would work. Not to mention it's a newer design so it will probably filter better.
Very true,if I can't source a good used HF/VX manifold this is what I may end up doing.. I'll keep this thread updated in case
Get rid of the cast iron and you have solved the problem.
regards mech |
