CRX HF EcoTurbo?
Well gentlemen.
Is it worth it to turbocharge a 1990 Honda CRX HF for increased economy? I read an article in SuperStreet a loonngg time ago, in which a turbo Honda S2000's fuel economy jumped to 38 mpg. All because it took him less time and throttle to achieve highway speed. I was thinking maybe a Mitsu 13G with an adapter plate to the HF manifold, plumbed straight into the throttlebody with no intercooler. Boost pressure would be low, only 5 psi or so. I would like to retain the factory 240cc injectors. My biggest concern is tuning with OBD-0. |
Doesn't the CRX HF have pretty high compression ratio already and with a turbo you want to have lower compression on your engine so the increased pressure doesn't cause pre-detonation.
The GT15 would probably be a little more efficient for my needs, and spool a little faster... However, that would increase the price by quite a bit. Quote:
The short answer is no. |
A guy on d-series.org boosted his civic for the sole purpose of better FE. He tuned it so that his engine would be in neutral vacuum as much as possible to increase pumping efficiency . He also re-calibrated the fuel maps in his ecu to run in lean burn mode. I forget how many MPG's he was getting but is was up there. I'll try looking him up and post a link if I find it.
I would be surprised if just adding a turbo helped FE in any way.
Using a turbo to bring a car back to "acceptable" performance when something else has been done (e.g., lean-burn, downsizing the motor, etc.) is a well-trodden path to FE. Just ask anyone with a Cruise Eco. It might be fun to run a 1st-gen Insight 3-cylinder with a turbo in a CRX. :D -soD |
Gasoline engines don't see much of a FE boost when turbo charged.
If you be good and drive them easy you can milk a few more MPGs out of your vehicle but the mod wont pay for its self. It would be nice to have more power and MPGs, in that way it could be worth it. I wouldn't try going non-intercooled. |
$20 for the TD04-13G from a friend ~$40 in steel and bolts to fab up the adapter and exhaust flange (I weld) ~$100 in exhaust tubing between the downpipe and compressor-to-throttle-body pipe ~$80 in plumbing and adapters for the oil, plus welding a nipple to the pan ~Free chipsocket (Nothing my Weller WES51 can't handle) ~Free tuning (BRE) ~Keeping 240cc injectors, since the boost pressure is low In short, there aren't a lot of expenses. No fancy tuning needed. No blowoff due to the low boost pressure. No intercooler needed due to the high efficiency, and I don't care if I lose 15 hp due to heat soak No whinebro fuel pump needed . In short, for under $500, my car would actually be able to merge onto the highway. Highway, I need to remember to pay attention to my RPM. I just know my fuel economy starts to drop off at about 68 mph. I think that's about 2500 rpm or so. I have gotten 55 mpg with this car before. That won't be possible again until next summer though. Back to the snow tires. Welcome to Michigan. That reminds me, I need to do a block heater. |
I say do it. Not only could you get better FE, especially highway, but the car would be more fun to drive. BTW are you sure you have 240cc injectors and not 190cc's???
