Old 07-16-2008, 05:58 PM   #1 (permalink)
Object on bottom of Prius behind front wheels?
There is an object on the bottom of the Prius behind each front wheel. It starts an inch or so behind the wheel well and runs along the bottom of the car for about 7". I could never get a good view of one from the side of a Prius, and was too embarrassed to crawl under a car to look (I don't own one). When viewed from the side this thing looks vaguely like a plastic cheese grater.
What is it called and what does it do?
Old 07-16-2008, 06:10 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
If I'm thinking of what you're thinking of I think it's an aero diffuser for the wheels.
Old 07-16-2008, 11:15 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
Mystery to me. I can't recall ever noticing what you're describing. Maybe one of our Prius drivers will chime in (with pics!)
Old 07-17-2008, 07:52 PM   #4 (permalink)
- - '10 Toyota Prius III w/Navi
Hi Pasadena...,
Its a belly pan add-on. Its smooths out the surface, except for the holes in it. From what I remember, it more like 3 foot long, and goes almost back to the rear wheels.
PBS takes the Hummer v Prius bait SVOboy Hybrids 51 05-19-2010 12:35 PM
Civic VX wheels or aftermarket? travr6 EcoModding Central 8 03-07-2010 06:37 PM
Active grill block idea holypaulie Aerodynamics 17 10-13-2008 09:31 AM
Front plate alternatives pasadena_commut Aerodynamics 8 07-12-2008 10:30 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 10:19 PM
