CRX HF: Stock motor vs vtec-e
Im asking for someone with experience here... what benefits would i achieve with a lean burn D15Z1(vx motor) or D16Y5 (96+ HX) over my stock D15B6 (HF, 8v sohc) ?? The motor itself has a very low powerband and i am averaging 49-50 mpg at stedy highway speeds. Im thinking most of the gain from the VX and HX cars are from the wheels and taller gears, so would there really be a benefit? added power is always nice, as the 70hp HF + tall gears can be pretty dangerous to drive on NJ 2 lane roads, but what about in FE? Any help appreciated! thanks!
The cam on the two engines I think is about the same if you don't count the Vtec on the D15Z1(vx motor), so the lean burn is pretty much what you are going to gain, either way you are going to have alot of wiring to hack together to make it work on top of fabricating engine mounts and forcing everything else to fit together, unless you are looking for an engine swap project I would start with the easy stuff like civic vx wheels or Honda Insight wheels, Honda insight aluminum rear brake drums, Low Rolling resistance tires, 0w30 oil in the engine and tranny.
