[CRXMPG FAQ] SuperMID and 1990 Toyota Truck
Recently got this question on www.crxmpg.com, my site:
If you have EFI, it's likely possible that you can use the superMID with the truck. However, there may be an issue with the size of the injectors as the range is limited (I believe) within the MID's programming. Also, is this TBI or individual injectors? If you have some more information I would gladly pass on your information/invite Yoshi here to comment on your question. Thanks again! |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
