Cugar controller HASS300 Curent sensor
Hy
Does anybody know if i can use HASS600 sensor on cugar controller or is there a simpler "cheaper " version of the sensor TNX for your help |
No, the current limit would be like over 900 amps. It would be really bad to use a LEM 600 without changing the software, but it would only be one line of code that would need to change.
You could use a Tamura sensor, which is like $14 or $16 or something like that, but you would also have to change the code for that too. |
