EcoModder.com
-   -   Cummins Ford Econoline Van Project (https://ecomodder.com/forum/showthread.php/cummins-ford-econoline-van-project-38240.html)
GillyF59 03-19-2020 10:27 AM
Good Morning, I started a Youtube channel to document my project build. ItÂ’s a 1990 Ford Econoline E350 ClubWagon that IÂ’m installing a 1995 5.9 12V Cummins with a NV4500 5 speed and a Gear Vendor Overdrive unit. The rear end gear ratio is a 3.54 limited slip. Final drive ratio out of the transmission will be .58 so based on that I calculated speed versus engine RPM and at 1525 RPM I should be running 70MPH. This van is being built to travel from PA to MT for hunting trips so IÂ’m hoping that I can get 25 mpg. Lofty goal??? I have plans for an aerotail and side skirts and a large air dam, all of which would be removable for the hunting part do the trip. IÂ’d like to get your feedback and advice as the build progresses.
https://youtu.be/E5oeu_d6XWE
Thanks,
Jonathan
cRiPpLe_rOoStEr 03-19-2020 02:00 PM
There might be some clearance issues, but that's a great engine. BTW what's the stock engine you'll be replacing with the Cummins?
GillyF59 03-19-2020 02:15 PM
Thanks!!! The original engine was a 5.8L 351 Windsor V8. The transmission was a C6 automatic.
Ecky 03-20-2020 07:24 AM
I drove a 1995 F150 with a large topper for a while though and was able to consistently get close to 20. It had Ford's 300 straight 6 (a 50 year old engine design) and not particularly tall gearing. I suspect if you can get your gearing tall enough, keep your speed down, and incorporate some driving techniques such as EoC, 25 could be realistic under the right conditions!
COcyclist 03-20-2020 09:04 AM
Gilly, cool project. I hope you can link some photos as you go.
Yes. However, I find Engine Off Coasting to be less necessary in a diesel than in a gasoline engine and may actually harm the turbo in some conditions. I use E-On Coasting and show 300-400 mpg on the ScanGuage while coasting.
Piotrsko 03-20-2020 10:49 AM
Engine should basically fit since they put 7.3 navistars in vans. Turbo will need custom pipes since Ford had to move the van turbo slightly. May have to modify the hot box.
Cali has a mandatory defuel on coast, which was implemented all 50 back in 2005 ish but only on EFI engines and I'm betting you are keeping the stock injector system and pumps
GillyF59 03-20-2020 12:14 PM
Did the link to YouTube work? I posted a link in the first post showing the engine and trans. in place. The setup fits likes a glove minus a couple little items but that’s to be expected. I will have to relocate the batteries to down onto the frame rail to make space for a water to air intercooler.
Thanks
Jonathan
me and my metro 03-20-2020 05:58 PM
Just watched your video, well done. Is it going to grow a front drive axle? I had thought about adapting a twin traction beam to one years ago when I had a club wagon.
GillyF59 03-20-2020 07:00 PM
Yes, it’s going to get a solid front axle. I know that will sacrifice some mileage but this is being for dual purpose use. I have a Quigley axle setup now but am thinking about upgrading to a 05+ Super Duty axle swap for the better brakes and turning radius. I’m hoping the big air dam and side skirts will make up for the added 4x4 axle and additional height that brings.
Thanks,
Jonathan
freebeard 03-21-2020 07:33 PM
I created this some time back for another thread.
https://ecomodder.com/forum/member-f...-1224-copy.jpg
Notable features
  • Pilasters on the front corners corner add a radius ahead of the wheelwells on the outside, and a converging duct into the radiator opening on the inside
  • Turnpike Cruiser-style skirts add a separation edge at the back
  • Mirrors are moved away from the A-pillar like newer buses and fire trucks.
cRiPpLe_rOoStEr 03-24-2020 07:09 PM
But a V8 is usually shorter than a straight-6, so there will still be some clearance issue to be addressed. No rocket science though.
GillyF59 03-25-2020 07:19 AM
1 Attachment(s)
That’s right but the only clearance issues I’ve encountered is that I have to relocate the Fuel Shutoff Solenoid and the “glove box” or one cubby in the dog box will need to shortened to give clearance to the rear valve cover.
Attachment 27759
cRiPpLe_rOoStEr 03-25-2020 03:38 PM
As I said, no rocket science. BTW I'm sure you might find some way to overcome any practical downside of having to get rid of some space in the glove box and a cup holder.
GillyF59 03-25-2020 05:16 PM
2 Attachment(s)
Actually with the newer console, it has everything I need so the slight modification will not make any difference.
Thanks,
Jonathan
Attachment 27763
Attachment 27764
cRiPpLe_rOoStEr 03-25-2020 06:01 PM
Don't forget the before and after pictures. A well-documented engine swap thread is always more pleasurable to follow.
BTW that has led you specifically into the 5.9 Cummins? Was there any other option you'd be considering?
GillyF59 03-25-2020 06:40 PM
Thanks, I’ll keep the pictures coming.
I chose the 5.9 Cummins because it’s reliability, simplicity and the ease of finding parts available to make it more powerful and efficient. Plus I had two of them here in the shop. Haha
Thanks,
Jonathan
cRiPpLe_rOoStEr 03-25-2020 11:48 PM
Well, even though a 4BT could already be enough for most former users of a V8 truck or van for professional purposes, a 6BT is also a great powerplant. It does seem kinda pointless that Cummins would only take so seriously on the repowering market with the R2.8 when it already had some good options on its parts bin.
GillyF59 04-03-2020 01:47 PM
Video update as requested.
https://youtu.be/BOgfn-419aY
Thanks,
Jonathan
