Cummins' Tips on Driving for Fuel Economy
Came accross this relase directly from "Cummins on Driving for Fuel Economy". given the growing number of Cummins drivers we have here now I thought I'd re-post it here.
Here's the link: Cummins Turbo Diesel News and the posting: Quote:
Cummins Engines - Newsletters - Turbo Diesel |
Also check out this "Secrets to Better Fuel Economy":
http://cumminsengines.com/assets/pdf...whitepaper.pdf Note: this is geared more towards semi trucks and the like, but most of the principles are applicable. The previous post was specifically for Ram truck owners. |
Good to see typical truck guys getting it !
We don't know if typical truck guys are getting it; it could be like Hardley-Abelson releasing a statement about the importance of quiet exhaust when the reality on the street is 98 out of 100 H-Ds have the stock mufflers ****canned.
Nice post. I have been using the scangauge(old as he--) to figure what works the best and making a few aero improvements as well so I hope the mileage will improve 10-20%, then Ill get the t-trailer and thats another fuel suck.
Thought the Cummins folks might get a kick out of this story too:
1.7 Million Miles in a Dodge Ram… You Betcha! Guy with a 2001 Cummins has run 1.7 million miles with his truck. I believe that's with no overhauls too! Here's an older article (back when he was only at 1.4 million) with some more detail: http://www.dieselpowermag.com/tech/0...500/index.html |
wow thats for me 1.7mil miles-soooo eco,I won't be driving like that so it will be oil changes as usual. 152,000 on my 1999CTD everyone said I should be able to get to 300 with no problem. so far ive only about 500mi in 2or3 months
160.000 miles/year is 440 miles / 700km each and every day !
Also, with all due respect to the gentleman, the factory recommended oil change interval is not 3,000 miles. The manual for the '07 truck that has pretty much the same engine (5.9L) engine, recommends 15,000 mi oil changes normally and 7,500 mi for heavy towing applications. I assume it was the same in '01. Still, at 440 miles a day, a 10,000 mi oil change means every 3 weeks! |
I drive so few miles a year now in my work truck that I only change oil every 6 mo. heck at 15000 mile change on a CTD Ill only need to change it every 3-5 years. I wont go that long once or twice a year sounds about write.
Glad you got those links up. Some of the other Cummins-specific information is, as you noted, for big truck operators. There is at least one Cummins calculator about truck spec, use, etc, that always recommends a higher rpm than pickups in general use will need, as with this post by Hohn, a Cummins Engineer.
Another post by that same gentleman goes into some more depth about proper rpm range for fuel economy. . |
hey slowmover do you yank that trailer around all the time . what is the difference in mileage with and without it.
(Here's that earlier Cummins info thread about FE)
Copyright ©2000 - 2022, vBulletin Solutions Inc.
