Custom Rywire Harness for 88-91 Civic/CRX with D15Z1 - $1000
Hello,
I have a custom-made Rywire Harness for an 88-91 Civic/CRX running a D15Z1 (Civic VX) engine. It's made to run from the engine to a P07 ECU code free (OBDI). This harness accommodates both EGR sensors (manifold & vacuum box). Included is a separate jumper harness, so you can use a wide or narrow band O2 sensor (4 pin to 5 wire O2 ntk sensor adapter). This harness is brand new and never used. I have the original receipt as well. I bought this 7 years ago for a project that never came into fruition. I'm located in the San Francisco Bay Area. I'll try to post some pics in the following days. Thank you for reading. |
Is it possible to run a VX ECU with a narrowband without a code?
I personally don't have the knowledge to answer that question. Maybe someone in the forum can. As far as I know, it was custom built to run code free with a wide or narrow band sensor and a P07 ECU.
