EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   custom scangauge install in New Beetle (https://ecomodder.com/forum/showthread.php/custom-scangauge-install-new-beetle-29145.html)
skyking 06-04-2014 03:28 AM
I have started the personalization on my Beetle :D
The rounded dash and steering column parts have a nice OEM look, but are not good for new radios, little doodads like a scangauge, etc.
I had it velcroed to the top of the column, but it obscured the fuel and tach, and I had to reach behind it to set the trip meter. Sorry, no before pics but it was about 3/4" higher.
I removed the steering console top and laid out a hole in it, 13/16" back from the front edge and 1" wide by about 4" long to start. The console top is held on by two #1 phillips screws from below.
http://i810.photobucket.com/albums/z...ps88df7616.jpg
I started cutting it in with a razor knife. Not too pretty yet, but I trimmed it up once I had the hole through.
Once I had the hole cut, it was obvious I needed to go wider. The shape of the hole was defined by the profile of a high part of the cover.
http://i810.photobucket.com/albums/z...ps1bc4f5fc.jpg
I cut it a little wider yet, and this is what it looked like from the side.
http://i810.photobucket.com/albums/z...psb47123db.jpg
On the top of the steering column there is a clip for a set of contacts, probably the horn and airbags. I took the scangauge apart and determined I could notch into the gauge itself to miss that clip.
I centered the gauge up and marked it with a pencil, and cut that with the razor knife.
I removed the board and display, of course.
http://i810.photobucket.com/albums/z...ps778f5083.jpg
Here is the final look. Before, the wire exited the right side of the gauge. Now it goes out the back and is totally hidden.
http://i810.photobucket.com/albums/z...ps887f5fdc.jpg
In that photo the column is adjusted all the way up, and is about 3/4" back from the front stop. That is the only limitation, you can't push the column all the way forward.
digital rules 06-04-2014 06:42 AM
Nice work Skyking!! Any glare issues?
mcrews 06-04-2014 09:19 AM
Big thumbs up!!!! :thumbup:
First rule of add-on:
1. put them in the same line of sight as other gauges!!!!
Second rule:
2. Mount them securely!!!
maybe you could add your picks to this thread?
http://ecomodder.com/forum/showthrea...e-18431-2.html ;)
skyking 06-04-2014 12:10 PM
None at all. I had it velcroed to the same place for months. It blocked the fuel gauge and the trip meter button. Now it blocks nothing.
skyking 06-04-2014 12:19 PM
1 Attachment(s)
I did not want to clutter up the column and stock gauges further, but wanted full instrumentation on my diesel so I drilled the dash way up by the VIN tag and stuck a 3 in 1 combo gauge up there.
http://ecomodder.com/forum/attachmen...3&d=1401899132
Dave's Civic Duty 06-24-2016 10:17 AM
Thanks for the link here sky. Think I'll get another ScanGaugeii. Advance Auto Parts has them for 20% off if ordered online, then pick them up at your local store.
BTW were you on Mopar1973Man.com? Thought I may have read your posts over there.
Dave3500
skyking 06-24-2016 10:23 AM
Not on his site as a member, but he is on a few forums I frequent. Feel free to copy my cut out, and I can get you the original images and also take some measurements.
The Scangauge has a nice blue color option that really is close to the dash light color. Looks great.
Dave's Civic Duty 06-24-2016 10:35 AM
Thanks for being so helpful! What holds the SG in place, looks level too!
Great job,
Dave
skyking 06-24-2016 10:40 AM
It's so tight in there, I think it is just a patch of double back tape.
Dave's Civic Duty 06-25-2016 04:42 PM
Thanks skyking, good to know! BTW, I like your 49.05 MPG. What is your mix of city driving? Open road? Do you keep it under 65MPH?
Thanks,
Dave
skyking 06-26-2016 07:24 PM
that's old data in the fuel log. I have not been a good boy :)
I am running about 46 in mixed driving and closer to 49 in pure freeway, under 65 driving. The big tanks I did get was back when I worked on Mt. Rainier, and had 19 mile coasts on the way home every day.
Dave's Civic Duty 06-26-2016 09:04 PM
I just did a hand calc on my last tank yesterday, 49.87MPG. Had my foot in her a few times, had some fun, mostly hiway. I guess I must remember how to drive from my ScanGauge on my Toyota.
I'm very pleased, better Summer mileage after I get the SGii. BTW, that's the highest mileage I've ever had on any vehicle I've ever owned! Yippie!!
Thanks,
Dave
skyking 06-26-2016 10:17 PM
I like it because it is fun in the corners, heavier for a good ride. I feel like I'm not being abused while getting decent MPGs.
Dave's Civic Duty 06-27-2016 09:20 AM
Total agreement, plus I like the option of running Biodiesel! Just use the commercially available stuff below B20.
Thanks,
Dave
