cx conversion to vx model
hi
I'm currently converting a 92 cx to a vx and started learning a lot about the vx 92-95 models first the block will be stamped with d15z1 the head will be stamped with p07-1 around the 2nd exhaust manifold port. the transmission is a s-20 manual also avalable in the cx model 92-95 still working out the exact #'S FOR THE INTAKE AND THROTTLE BODY . I do know that the the o2 sensor is a 5 wire wide band LAF sensor ,there is a 4 wire o2 sensor for the California version. the ECU is a p07 and one of the rare parts is the EGR control box on the rear fire wall. as i near completion on this project i will post a complete list of all parts, pics and steps to complete this conversion( also list of cars to get interchangeable parts from and links to confirm all data. so lets covert some cars to be friendlier not faster "any info or advice to help with the project would be welcomed " |
