California98Civic |
05-21-2013 02:11 PM |
Originally Posted by Jakins
(Post 372502)
does anyone know how to tell the difference between the super awesome civic cx/vx transmissions and the super mediocre dx/LX transmissions? supposedly they are both stamped p20 A000 even though they are both very different. im trying to get one for my civic HX. which also brings up another question. will my current VSS work in the cx/vx transmission? thanks dudes!
Since fith gear is the same on both sets of transmissions, the only way is to put it in 4th with a clutch plate installed and marked and count revolutions against the differential. Can be done with the transmission off the car and without taking apart tranny, I am told. I did not do it myself. I took the chance. And I got what I needed: a CX tranny from 1993.
EDIT: I found where Old Mech (I think) had posted this method: "get an old clutch and mark it at 12 o' clock before pushing the shift rod into the trans, putting it in 4th gear (0.853). Mark the differential. The final drive is 3.25 and 4th gear is 0.853, so 3.25 * 0.853 = 2.77225. Therefore it should take 2.77225 full revolutions of the clutch to make one full revolution of the differential. It should turn 2.77 times and end up pointing a little after 9'o clock to make one full revolution."
Good luck!
