EcoModder.com
-   -   D15b vtec-e ecu (https://ecomodder.com/forum/showthread.php/d15b-vtec-e-ecu-12718.html)
ef9 03-24-2010 05:32 AM
D15b vtec-e ecu
Can i use P08 ecu to my D15b vtec-e engine right now im running P07 ecu?
thanks
scottied15 02-12-2013 04:38 PM
i have the proper p2j ecu if your looking for one!!
slownugly 02-12-2013 05:30 PM
P08 is for a performance vtec engine I believe. P07 is the correct one for vtec-e. I think the p08 used a one wire 02 sensor while the p07 uses a 5 wire wideband
