D15Z1 injectors?
When I got my D15Z1, it actually had a 1992-1995 DX/LX intake manifold attached to it. And the D15Z1 manifold that I got had no injectors. I thought that I could just use the DX/LX injectors, as I have always heard that ALL B and D motors use 240cc/min injectors. But I was recently told that the VX uses lower flow injectors. Is there a more common Civic model that uses these same injectors? For instance, will 1992-1995 CX injectors also work?
As far as I know, the CX and VX are both 190cc injectors. This might also be the case for the HF (I have heard as much), but they need the resistor box anyway. I'm currently running CX injectors and I can confirm they are different from DX (though I take the 190cc bit for granted).
I'm going to see if I can afford the $20 to have my set of VX injectors tested here before spring. I'll be sure to post results, and as always, donations are appreciated ;)
Tomo, where is this place that tests injectors? I'm about 50 miles away from Minniapolis and I'm wondering how much wear my injectors have after 248,000 miles... would be willing to pay $20 each to have mine tested... any idea how long it takes to have this done?
The person is in Mankato, MN and only charges $20 for 4 injectors. No idea how long it would take this person yet since I haven't been able to budget $20 for it, lol. I'm up to about $10 saved for this purpose. All I have is a PM address for him and no email as of yet, so if you would like me to contact him on your behalf, I can do that.
