d16y5 long block and transsmission
d16y5 engine and 5 speed trans for sale. engine was pulled from my car on 8/28/16 to replace it with my new build. the milage is unknown but is around 280K +. it was runing and driveing every day till pulled. the rings are worn but did not smoke.the trans needs a rebuild because the input shaft bearing was making noise.im in columbia south carolina just fyi for pick up.
