Daimler, PGE Open 'Electric Island' Charging Site
This is the first station for the West Coast Clean Transit Corridor Initiative to install charging station for HD trucks along the full length of I-5.
8 pull-through stations with 250 kW chargers. The site has been build with enough electrical service for 1 MW chargers when they become available. https://www.truckinginfo.com/1014176...-charging-site https://fleetimages.bobitstudios.com...-720x516-s.jpg https://fleetimages.bobitstudios.com...-720x516-s.jpg |
What kind of connectors does it use? 250 kW isn't much for a truck-sized battery.
I see a substation of sorts was required to supply that enormous capacity. What percent of utilization is required to break even on the fixed and variable costs? I think I read somewhere that DCFC typically requires 1/3rd utilization, meaning 8hrs of billable charging per day to break even. ...might as well install the chargers on I-5 so the trucks can top up during the 5hr "rush hour" where I-5 converts to a parking lot. |
Big trucks only I hope? Some eedjut in a tesla parked for a 1/2 hour not charging would be annoying more that it already is.
I'm surprised it's only 250 kW.
Ionity has mostly 350 kW chargers with Type-2 CCS for cars here. |
https://cdn.motor1.com/images/mgl/Wm...rging-site.jpg Quote:
"The site is built to immediately provide charging for EVs of all shapes and sizes, and will serve as an innovation center, allowing both PGE and DTNA to study energy management, charger use and performance, and, in the case of DTNA, its own vehicles’ charging performance." Quote:
Different articles have different numbers. Some say 150 kW, some 250 kW, and some say 350 kW. Unless something has changed from earlier press releases they are 150 kW with the dual plugs capable of charging at 300 kW. |
On demand power of 250kw to a few megawatts isn't going to all come from renewable power unless you're hydroelectric or geothermal heavy.
Yes, we are very hydroelectric heavy. About 2/3 rds of Oregon's electricity is generated by renewable sources. |
You said this charging station wouldn't be powered by renewable energy unless we have a lot of hydro. We have a LOT of hydro. |
1 Attachment(s)
The "Electric Island" is on Plug Share.
4 CHAdeMO, 7 CCS plugs. From the pictures they are all different brands. First review says they are free. Attachment 30583 |
Are these things only going to be used there? What about the rest of the United States where there isn't an abundance of hydroelectric? Quote:
Nothing in the goal says they will be only provided by hydro or geothermal or even renewable electricity in general. However, all 3 states along I-5 have cleaner energy than average and have specific goals to continue transitioning to larger percentages of renewable energy. That is one of the good things about EVs - as the grid gets cleaner your car gets cleaner. |
