"Daisy-chain" two SGII's together?
...has anybody tried this -- daisy-chaining two SGII's together to double the amount of displayed data? http://www.fuel-saver.org/Thread-Sca...-II-and-XGauge
http://i241.photobucket.com/albums/f...0lowvalues.jpg |
I haven't tried it but it does work.
...double the numbers, doubles your milage (I wish)?
Doubles the amount of time you spend looking at instrumentation instead of the road, too! :)
I've also seen it done, in a Prius. |
thats hypermiler bling right there
im paranoid as it is with 1 SG on the dash |
if you run multiple scan tools
you should run into update rate problems as the ECM can only respond as fast as it can More PIDs reporting always slows down each PID update rate for purposes of storing the info / data . and safety. you can log the PIDs as you drive and play them back later with Speedtracer a free tagalong to AutoEnginuity recently updated to version 5.o with the 8.o1 release of AE and Escan is threatening to release a similar type of FE calculating software in a future release ... http://farm3.static.flickr.com/2797/...447d6740_b.jpg |
...I'd like to see a simple USB port that you could simply plug in one of the USB "Thumb Drives"...with 16GB currently available, you could surely store a LOT of data! |
during the testing -
the data is stored in Mr laptop which resides on the passenger seat or on the lap of the co pilot the laptop screen is NOT to be viewed by the driver during the test , to avoid crashing into something ==================================== Quote:
