Is This Dc Motor Ok For Chevy S10? I'm New To This
Hi,
I'm new to this, still learning. Can someone tell me if this DC motor is good or not for a Chevy S10? Here is all the info from the tag. DC volts 36/48 KW 14.1 RPM 1325 Amps 330 GE# 5BT1366B162B LENGTH: 17 inches DIAMETER: 11.5 inches WEIGHT: 200 lbs It is from a 5,000 LB Forklift. I was concerned because of the low RPM but not sure how much that matters. thank you! |
I'm thinking about putting that guy on my 250 motorcycle :)
So how fast does your truck go in top gear at 1325 rpm? That will tell you the top theoretical speed without attempting regearing. |
LOL - eBay battle on EM... go figure :P
the speed?
I don't know any speed yet, it's in an old Hyster forklift that I'm dismantling right now. Just wasn't sure if it was any good? Can it be overpowered for higher RPM?
I can discuss it after 4pm today.
hah? why 4pm? I guess this is my last post. I thought this was some helpful forum where you could get assistance and learn? You people are a bunch of jerks. Why make fun of me? I was just trying to learn and get advice, just like you needed when you were first introduced to all this. I'll certainly tell the other forums to stay away from this one, thanks for all the ridicule and help. I'll go somewhere else for it.
no no, what speed are you doing currently when your GAS engine is at 1525rpm? IE, at 1325rpm in top gear I'm at 45mph in my S10. Now your turn.
edit: Wow. You apparently don't understand sarcasm or jest, and have taken everything said literally and to heart--where it promptly stabbed you viciously. /thread fail. |
He'll tell you after 4pm, because that is when it closes. I have seen the motor and it look pretty nice, If you can out bid me!!!;)
Well jeez...
I KEED I KEED!!! |
