A decent acceleration calc
I was interested in approximating how much adding a X lb/Y hp electric assist system would shave off my 0-whatever times. The problem is, most 0-60, or 0-anything really, calculators I've found online are wayyyy off. Then I remembered that someone had formalized acceleration already, so all I had to do was plug and chug. That said, it's a bit jumpy and there's at least one typo, so I figured that messing w/ latex never hurt, and pumped out some intermediate steps.
We start out w/ the tried and true, http://www.physicsforums.com/latex_i...ew103277-6.png Scourge of introductory physics students everywhere. Then, since we're looking for acceleration in terms of speed, we divide power by speed to get force. http://www.physicsforums.com/latex_i...ew103277-5.png We also know acceleration is just the instantaneous change in velocity over the instantaneous change in time, so w/ some substitution we get... http://www.physicsforums.com/latex_i...ew103277-4.png And a bit more algebra gets us. http://www.physicsforums.com/latex_i...ew103277-3.png Integrate both sides and we get time as a function of velocity. http://www.physicsforums.com/latex_i...ew103277-2.png Which is... http://www.physicsforums.com/latex_i...ew103277-1.png In terms of rolling/aero drag. With tau*v being the power generated by the engine assuming the torque curve is flat. Finding tau is easy enough, just divide peak power output by the maximum speed in whatever gear we're in. We can even get a power curve for a powertrain that doesn't have a flat torque curve, although that's an exercise for the reader. Now, the problem is, that looks pretty nasty, so we simplify the coefficients... http://www.physicsforums.com/latex_i...ew103277-0.png Pop it into Wolfram's online integrator, and... BAM! Still looks kinda nasty, eh? The arctan of imaginary numbers? Bleh. That's O.K. We're lazy, and we know it, and we also know about this nifty free little math program called octave, available for *nix and windows. We grab that, and can now evaluate this little SOB easy peasy. The only thing easier would be if I made a program w/ this algorithm in octave, which I hope I'll get around to later, but I figure this is good enough for a start. Now we have an accurate approximation of acceleration in whatever gear between whatever speeds, which is great for those interested in dropping in an electric motor or hybridizing who want to get an idea about performance, as well as anyone who wants to see what changes in HP/weight will do for acceleration. As a double bonus, accelerating for a while in whatever gear at higher speeds may also allows us to calculate the drag area with greater resolution, and for those of us who don't know what our drag area is, the manufacturer's 0-60 times, along with some educated guesses, can result in a decent approximation of it. Also, if torque isn't flat resulting in a non-linear power curve, tossing in a polynomial for engine power doesn't change the outcome much, so we can deal with all sorts of drivetrain combos, even a shot of nawzzz, brah. ;) P.S. It seems pretty accurate too. I plugged in the numbers for my mercedes project, assumin Crr=.1, drivetrain efficiency is 85%, given the different speeds in gear and curb weight, and in order to get a 0-60 time of 27.2s, plus the time needed for 3 shifts, which is supposedly boardline line for .6s shifts, for the stock 29s 0-60, I had to go with a CdA=.75m^2, which seems about right since it's has a little less reference area than the Camryaro, and almost certainly a higher drag coefficient based on looks alone, so overall the drag area should be a bit higher. Fooling around w/ it also shows how halving the drag area can substantially reduce the time needed to accelerate at higher speeds. For example cutting the drag coefficient of the average small pickup truck in half would shave nearly 10s off of the truck's 0-80mph time, and 5s off of it's 60-80mph time. Edit- physicsforum took out my bandwidth stealing butt, so I'll host the latex images someplace else later. |
...and, the s-i-m-p-l-e answer is...what?
Plug and chug baby. You may have to tweak the expression for engine power if the torque curve isn't more or less flat, but that's the only thing to do, everything else (speeds in gear, curb weight, hp, rolling resistance, and aero drag) is plug and chug.
Alrightly, I have some primitive code for some really convenient plugging and chugging. This is only for acceleration in one gear, so to find acceleration to some speed, you will need to add all the different times for acceleration in each gear you need to get to whatever speed, plus the shift times. It also assumes a relatively flat torque curve, so if someone's engine/motor's torque curve isn't flat, they'll have to modify the code.
Anyhoo... Install octave, and use a file editor to open the accelcalc.m text file, and paste this in there. Code:
function z = accelcalc( mass, drag, roll, spd1, spd2, spdt, power, eff) For instance, the (not my yet) Mercedes 190dc weighs in at 3000lbs, which is 1360kg (I use onlineconversion.com for the conversions, but y'all can use whatever works), has a drag area of about .75 square meters, has 133N associated with rolling friction (has tires w/ a Crr=.01, and has a weight (weight is a force) of ~13300 newtons), is starting from 0mph or 0m/s, is going to 20mph or 9 m/s in first gear, has a top speed of 9m/s, has an engine that makes about 52hp or 41,000W at peak power, and has an assumed driveline efficiency of 85%, so that's represented as .85. All together, this means my input in octave will look like Code:
accelcalc(1360, .75, 133, 0, 9, 9, 41000, .85) Code:
3.2913 Code:
accelcalc(1360, .7, 133, 0, 15.5, 15.5, 138000, .75) Code:
3.241 What's really cool is that there seems to be a lot of resolution for top speed runs, at least for manual transmissions that won't kick down. For instance in the Merc, a ~6+% reduction in drag results in a 12s change in the time needed to accelerate from 53-72mph, so there's quite a bit of resolution in terms of calculating CdA. Newer cars w/ more power would need to find a nice steep (unpopular?) grade so they could accelerate at WOT w/ the same amount of resolution w/o breaking the speed limit. Edit - Does anyone want to incorporate a gearing calculator, so people don't have to figure out the maximum speed in each gear on their own, or would that take too many inputs? Maybe I'll just make another .m file for that... |
wow. I am confused. complicated. I can only assume there is too many factors to take this challenge. Unless efficency of engine is guessed as all the errors, like advance speed, (electrical) vacuum, tire pressure, terrain...
It isn't that complicated. ;)
Engine efficiency, advance speed, and vacuum don't matter, at least from the perspective of the calculator. All we need is a set of data for the torque curve to get power from the engine versus speed. I suppose you can change the torque curve by changing timing, fueling, and so on, but all that's needed is a torque curve. Tire pressure is incorporated in rolling resistance (Crr), which can be experimentally determined by the owner. Terrain can be accounted for the same way power can. |
I have a question (sort of related to this thread)
In theory, assuming zero drag, does it consume more energy to accelerate quickly to X speed or slowly to X speed. The final kinetic energy is the same so if there are losses where do they go? Is the energy required to accelerate an exponential curve with greater requirements for faster acceleration? My understanding is that it's the same total energy to get an object to X speed but since it's over time then to accel to the same speed in half the time requires the same amount of energy twice as fast. Am I on the right track here or is my grasp of physics slipping? |
The neat thing about CVTs is you can pick the RPM and load and stay at that RPM and load while you accelerate.
I found on my Insight, with a CVT, that you could very gradually accelerate with a very slight loss in fuel economy then semi glide and increase your mileage significantly, while still in gear with the engine running all the time. This technique allowed me to hit 80 MPG on occasion in my normal daily route of 40 miles and over 45 traffic lights, at a 38 MPH average speed, 20 miles in and 20 miles return. Under high rates of acceleration the fuel consumption could be as much as 500% of the steady state consumption. I plan of doing some testing with the Altima to see what the difference is in accelerating at different RPM rates, ranging from 1200 to 3000 RPM and possibly higher. It takes the MPG computer 30 seconds from a reset to give a measurement, so you can start from a reset and acclerate at different rates to see which rate gives you the best mileage from a stop to a certain speed as long as it does not take more than 30 seconds to get to that speed. My guess would be the best rate of acceleration would be about 2200 RPM, but you never know. I read a post elsewhere by Sentra where he stated he used 8 second pulses in his Pulse&Glide tactic. I am assuming he has spent considerable time testing for best effectiveness as far as overall economy. While his glide segment changed depending on his average speed his pulses were almost exclusively around 8 seconds if my memory serves me correctly. regards Mech |
-soD |
In terms of the calculator, there is a path that optimizes acceleration and fuel efficiency, but in practice that depends on the transmission specifics, especially for automatics, but also for manuals since they both have different efficiency curves compared to engines or the type of transmission used for SAE testing. |
Does it require more energy to create the same amount of kinetic energy? ball 1: 10mph in 10 seconds vs ball 2: 10mph in 5 seconds. Theoretically, I don't think it does. I'm just trying to confirm this so I can fully understand. Getting back to cars: If all the difference in losses between accelerating faster and slower have to do with engine efficiency then there is no limit on how fast you accelerate for FE but the engine BSFC. I realize there may be other factors like increased friction. I was under the assumption that the energy required to accelerate to X speed over time was exponential but I now think it's directly proportional. Just cant seem to find a source that can confirm this. |
Lets say you need 600 HP seconds of energy to get your car to 60 MPH, assuming all the other loss sources (aero, RR, mechanical friction in drive train, etc) were eliminated, then your source of that 600 HP-sec would be most efficient at its best BSFC (without time as a constraint).
600 HP-secs for 1 sec 300 HP-secs for 2 sec 100 HP-secs fro 6 secs I can't see any reason for that to become proportional, however that is mostly instinct on my part, and could be refuted easily with a logical counter explanation. It is basically changing the inertial state of an object moving in a linear fashion. I do stumble on the exponential cost of accelerating a flywheel, but have seen that just running an engine with no load at different RPM seems to use a linear volume of fuel. regards Mech |
Today I did some quick tests.
0-40 then cruise engaged. Total time was 30 seconds. I accelerated at 3 different RPM. With the CVT you can maintain a constant engine speed while accelerating. 3000 RPM=19MPG 2000 RPM=20MPG 1500 RPM=23MPG Now the variable is total distance since the 3000 rpm acceleration was about 3 to 4 times faster than the 1500 rpm acceleration. This means you travel less total distance when accelerating more rapidly, which increases the time you would cruise to the same distance. At 40 MPH this car averages about 45 MPG so I think it would be a wash overall if that was considered. I guess I could do the test from point to point to equalize the distance, but then the 30 second reset time on the instrument (factory) in the car would not work since the time would be in between 30 second intervals. Doing the test like this I just reset the meter and started off and the first reading was the figure I posted. I would say within reason it probably makes little difference as long as you do not go to extremes like WOT. My car supposedly does 0-60 in 7.5-8 seconds with the 2.5 4 cyl and CVT. regards Mech |
On this regard I think the only way to REALLY know the best way to accelerate would be to repeat the same trip in the same conditions day after day using the scan guage to show how much fuel over the current trip has been used in ML and how far you have traveled in meters (if it would do such a thing), procede to test a 1000m drive by accelerating hard to the same speed and go that distance, repeat with the different variables up to the same speed day after day until you determine what makes your vehicle use the least gas to go that distance.
Now any ideas how I get my SG to display how much fuel I've used so far in reasonably small units and likewise to display the current distance traveled on the current trip in reasonably small units? I would like to log this with temperature to figure out what form of acceleration is really the best over time. BSFC doesn't always match reality. Cheers Ryan |
For cars in general the limiting factor is engine BSFC and for automatics tcc lockup since torque converters are really inefficient. The energy required to accelerate to some speed, assuming a manual trans or tcc locked most of the way is proportional to the speed squared. Since brakes are just devices that turn KE into heat, braking distance is also proportional to speed squared, eg someone's KE/braking distance at 70mph is about twice that of someone at 50mph. |
Tractive effort power looks like the road load force + the inertial forces times the velocity. The true aerodynamic resistance can't be ignored in the real world and can play a significant role in the over all resistive components of the Road load power =(rolling resistance*mass*gravity*cos(theta)[(rolling resistance term)]+1/2*rho*cd*0.8*af*v^2 (aerodynamic drag term)+m*g*sin(theta) [Grade resistance])*v.
Therefore the acceleration force looks like Pte-Prl as mentioned previously but the driveline efficiencies cannot be ignored or assumed at a single reference value, also the inertial term changes with each gear, the effective mass is not a constant, its highest in lower gears. I could go on, but that's enough for now |
Pretty much. Rolling resistance and the drag coefficient should be expressed as polynomials through interpolation from actual data in addition to inertial forces and an expression for the efficiency of all the driveline components, but all of that data is a pain in the ass to come by. I imagine inertial force should even be a function of whether or not the tcc is locked.
