Deleted Tanks
Just wondering about this. I had somehow typed the same tank twice (most recent) so I deleted the second tank which worked except that it stayed on the bar graph. I added a "fake tank" to eliminate the offending bar which worked in removing that second bar and replaced it with a new tank. I then proceeded to delete this fake tank thinking the reason the previous bar stayed was because it was the exact same entry as the previous one. Turns out, any deleted most recent tank will stay there until a new tank is entered. Does this happen to everyone else? Is this a bug?
I think it just takes time for the bar graph to update. Whenever I add a fuel-up, it takes a while to see that entry in the graph.
did you try refreshing the page after deletion?
When i add tanks i have to refresh the page to get the fill up to show on the bar graph, so it mite be that way with deletion |
yeah, I've refreshed. I even checked again today, that false bar is still there for some reason. I think to get rid of it, you would have to delete both the wrong and the right bars then reenter the right info so it updates with only that one. I'll try that right now, see how it goes.
Edit: Just deleted the correct info, It says that the bar graph does not update until you add a new entry or edit an existing one. It seems that they know of this issue. And My method did work, Only correct info bar is there now. |
