EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   Diesel Dilemas (https://ecomodder.com/forum/showthread.php/diesel-dilemas-28716.html)
g2taylor 04-15-2014 09:16 AM
Diesel Dilemas
We own a Ford F-250 that sucks down the fuel anyway...but when you add pulling a pontoon or a bumper pull camper to the equation...GEEZ!
I want to design my own light weight cab-over camper that will not only serve as a comfortable place to sleep, but also provide an aerodynamic function that will help when pulling our trailers.
FYI:I found this site while searching for DIY cabover camper designs.
Frank Lee 04-15-2014 02:01 PM
If your trailers aren't taller than the cab, a cab-over camper will add very much unwanted frontal area.
cRiPpLe_rOoStEr 04-15-2014 03:03 PM
Maybe a camper with a pop-up roof, even without the cab-over part (unless you could make it also foldable) would be a good solution regarding aerodynamics.
