Diesel Fuel Preheating
From the preheating threads and Squirrl22's reply in the engine mod thread got me searching.
I might think about using a counter flow chiller to heat diesel with coolant by installing it between the filter and injector pump. The hard part will be installing a tee in the coolant path to and back for flow. Has anyone tried some thing like this on a TDI or any other direct injection diesel? Do you see any down sides or issues to look for? I will need to figure out my transmission issues before I start doing work like this though. |
that shows a great deal of promise. I have 3 diesel rigs, and this week I was operating my truck in 5 F temperatures. The fuel and IAT temperatures were far from optimal :(
Cummins marine advises against heating fuel beyond 125°F and actually recommends keeping the fuel close to 75°F to prolong injector pump life and the best fuel economy.
You don't need to heat the fuel since the injectors are screwed into the cylinder head. So by the time the fuel is injected it's already at cylinder head temperature. I have an artic fox fuel heater to install. I'm going to limit it's temperature to around 100°F. |
Ask the svo guys. They are in to fuel heating.
I have a tentative plan for tapping into my heater core coolant hoses, and making a heat exchanger that has about a pint of volume. Get it as close as I can to the engine mounted filter/water separator. I don't know if my OBDII give me fuel temps or does anything with them, But it seems that 75 F fuel could never hurt, and may help. |
The only diesels I know that run fuel that is even kind of heated up are snow cats. They heat the fuel to 120 to 125°F. That's just so the fuel doesn't gel in -40 temperatures with 80mph winds.
But they don't use CP3 pumps. |
