Diesel Particulate Filters.
It would appear that many UK motorists are driving about without Diesel Particulate Filters. The current MOT doesn't always pick up if it has been removed, and though illegal to drive a car without one it is not illegal for a garage to remove it. A change to the MOT will improve the situation, but there are also calls for spot checks to be carried out on diesel vehicles (as there currently are for checks on the fuel being used).
'Thousands' driving without crucial diesel filters - BBC News |
DPF filters decrease fuel economy.
And they still create DPM in the most dangerous particle size of 1 to 2 microns. I say if you are not in a city with a smog problem lop them off. |
I'm glad it is.
If paying more for fuel and getting worse fuel economy helps you sleep better at night go for it. But you are producing way more CO2 with the DPF. |
I have no choice what I pay for fuel. Nor am I advocating DPFs. I am just saying we can hardly move in the UK without passing through a large town or city. I live 30 miles from Scotland's capital, Edinburgh, with some real pollution hotspots in the city. Edinburgh is a smaller city than Albuquerque. The law here does not allow the removal of DPFs and I believe in the rule of law, however inappropriate that particular law is. I am just happy I don't drive a diesel, and never will.
They'd never get away with spot checks in the US. Can't pull someone over with no evidence of a law being violated.
This is the UK law on Spot Checks:
The police can stop a vehicle for any reason. If they ask you to stop, you should always pull over when it’s safe to do so.You’re breaking the law if you don’t. If you’re stopped, the police can ask to see your: driving licence insurance certificate MOT certificate If you don’t have these documents with you, you have 7 days to take them to a police station. You’re breaking the law if you don’t show the requested documents within 7 days. The police can also give you an on-the-spot fixed penalty notice for many minor offences and make you take a breath test in certain circumstances. You can also have your vehicle seized if you’re stopped on suspicion of driving without insurance and for some other offences. Usually they stop you for a lighting offence or less than ideal driving. |
You can be pulled over for emissions spot checks if you are a commercial vehicle.
Your statement is applicable to current technology.
And DPFs don't necessarily "create" small micron particles. The whole system of DPFs and high pressure fuel systems in diesels biases particulates toward the sub micron range. I think you are aware that gasoline direct injected engines also create these single digit micron particulates. They are under scrutiny and may need remediation as GDI is becoming ubiquitous. |
Unless big changes are made the current design of DPF is pretty bad for fuel economy.
Modern diesels don't make much smoke unless someone puts in a retard program to purposely make lots of black smoke. |
Yeah, lets start with getting the morons who roll coal, or drive around with a failed turbo off the road.
When a dpf does a regen it actually pumps out all the soot/carbon that has built up. So the law is law but in this case is seems so wrong. Dumps in one go instead of being spread out in time.
It uses fuel to burn the captured diesel soot, then it does produce soot that is 1 to 2 micron which is most hazardous.
My old diesel, what soot it makes is big 100 to 150 micro. You can see it and smell it and that's a good thing, our bodies can stop almost all of that before it gets into our lungs. The problem with the 1 to 2 micron size, that's the size chemical weapons manufacturers are going for, so it gets inhaled deeply into the target's lungs. |
