Diesel vs petrol question
I drive a courier van, ford transit, manual 6 speed, diesel, 2.2 litre I think. Over a 480km trip, 90% at 100km/h - 60mph, it regularly gets 6.7-7.0 litres per 100km. My car, 3.5litre V6 Camry, petrol, 6 speed auto gets 7.4 litres per 100km on a good trip for the same road at the same speed... over many trips. Van has a far larger frontal area and is fairly brick shaped, has a bull bar too and Im pretty sure its heavier.
Why can the van do better than my car? I understand auto vs manual but there must be more going on, does diesel have far more energy per litre? I drive the van pretty hard but usually I am in no rush in my car. |
Yep, diesel has more energy per unit, plus diesel engines have a more efficient combustion process.
Work vehicles are often (maybe usually) geared for steady state cruise. Can handle being fully loaded in terms of overall powertrain performance. But can slow up to speed.
Passenger vehicles are overpowered. Set up for acceleration. While not strictly accurate, the above makes sense when one tries to use one vehicle in place of the other. |
If the diesel is a turbo diesel then it really isn't fair.
You have 2 engines in the diesel versus one in the gas. That turbocharger is working to recover waste hest in the exhaust to force more air into the engine. Diesels get better fuel economy with more air. |
Yes, they are more economical but they are more harmful to the environment, they are carcinogen when breathing fumes, and they are more expensive to repair but these new cars with this engine.
Is burning more fuel not also harmful to the environment? |
If you live anywhere near Autobahn 40 in Germany you'd better think twice before buying a diesel car...
https://www.carscoops.com/2018/11/ge...obahn-network/ Here in Holland more and more cities move towards banning diesels of a certain age, or altogether, in order to meet the micro particulate and NOx air pollution standards. Recent research has shown micro particulates are far more harmful than was previously assumed, so there's no turning back this trend. Diesel is on its way out, especially in densely populated areas. |
Anti-diesel ”reasearch” is pretty well bunk. Politically skewed. Like the faked dangers of second-hand cigarette smoke. False, in that someone’s profit (or power) is what’s really at stake.
The energetic content of diesel makes it indisposable. Non-replaceable. Emissions controls have changed the rest. The number of vehicles to service urban sprawl is the problem. Why cities have sprawled is what you aren’t allowed to ask. “Why do we have commuters?” Power and profit are at stake. Other choices would have precluded what you think of as a dilemma. . |
Oh yeah, it is pretty well bunk.
https://en.wikipedia.org/wiki/Diesel_exhaust Quote:
But if you have decent fuel there isn't any need to. Over here advancing diesel injection timing is done for emissions control. |
It’s context. Not content. Pay attention to a larger picture. |
If you believe diesel exhaust gases are safer than even the best tap water you'll have a hard time finding others who share your views.
I think we won't convince each other anytime soon, so its better to stop trying. |
Shows you don’t understand even that problem. More serious. Bet you think secondhand cigarette smoke a problem, too.
Few studies can stand up to replication tests. Best you examine your thesis A LOT more carefully. |
The problem with the studies is they haven't sufficiently controlled the variables.
Studying miners in a confined space, breathing diesel fumes 10hrs a day isn't a good predictor of the amount of exposure regular folks inhale in day to day living, and what the consequences are. There's no possible way to put a number of deaths that diesel particulates are responsible for, not to say it isn't happening. A heart attack triggered by diesel particulate inhalation which results in death doesn't mean the diesel particulates have killed the person; it's entirely likely it's the straw that broke the camel's back, and the person would have succumbed to poor health in the near future. Again, not saying we should not concern ourselves with the quest for cleaner air, only saying that the issue is too complex to simply say millions of people are dying as a direct result of pollution. How much longer would these people have lived if they had been exposed to 1/4 as much pollution? We'll probably never know. |
Remember Europe doesn't have all the emissions stuff we have in the US.
The sulfur content in the European fuel is a lot higher than than the US.
We use 7ppm sulfur because of the emissions, this started back around 2007. When did Europe start using their sorry excuse for low sulfur diesel? We had to start using passive PM soot traps in the mid 90s, most diesels sold in the US had to have very high pressure common rail full electric injector control by 2000 to control NOx and PM, early 2000s egr coolers were needed to reduce NOx, 2007 was the ultra low 7ppm sulfur fuel roll out, then in 2010 active soot trapping using exhaust filters that regen and strict NOx emissions, 2013 or 2014 very strict NOx regulations force use of urea augmented converters on most diesels. |
Well this is all new information for me about the american emission equipment, thank you for that. I don't know when they started reducing sulfur in european diesel, one finnish refinery did it in 1991. Someone with better knowledge can correct me. |
I don't think the research was anti-diesel. Its results were anti-diesel though.
Does that make the research bad? If research needs to give the results you want to not be bunk, it isn't research anymore. |
I value the results of scientific research, where researchers tie their names and reputations to, more than the words of politicians. Even though the latter generally have a more pleasant message (depending on their orientation).
I have nothing with left wing politicians, but 'left wing' research is not a real thing. Nor is 'right wing' research. I was disappointed because the particulate research I brought up was immediately declared bunk, "research" even. As if I would post it if I thought is wasn't real. So it is in effect an attack on me too. Guess what, I can do without that. |
I'm sure the research is as fair as you can get with funding bias.
Yes left leaning politicians pretend to care about the environment. But their version of caring turns into something that resembles neglect, mismanagement. It's even hard to tell if their will towards the environment is just ignorance or intentional malevolence. |
Emissions regulations have let off some aspects of diesel in the past. As diesel engines run lean on light loads by concept, they produce less CO and more NOx than gasoline engines. Yet emission standards are pushing the levels down: Fact Check: are diesel cars really more polluting than petrol cars? The problem here is that many diesel cars cannot actually meet the standards, that's why dieselgate is so widespread. Gasoline cars generally do meet the emissions standards (but not the economics...). Also the standards do not yet distinguish between micro particulates and larger particulates. Direct injection cars (diesel AND gasoline) produce more micro particulates than carbureted or indirect injection cars; in that aspect the old diesels were less dangerous than the modern 'clean' ones. But it does contain less benzene: https://www.quora.com/Why-is-benzene...-not-in-diesel This is a nice neutral description of diesel and its use: https://www.globalsecurity.org/milit...iesel-fuel.htm and what it does to us: https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4894930/ Quote:
My van does highway km so is ok but many cars here - Australia- have problems with the diesel particulate filters that they have to have.
Can anyone explain why diesel has particulates when burnt but petrol does not? |
The way I understand it is: it is all about controlling NOx emissions. There are two schools of thought, the first is lots of egr to cool the charge. The problem with lots of egr is lots of soot, so you have to trap it and burn it with the cat and extra fuel. The second is not so much egr which makes more NOx but less soot, then kill the NOx with urea. I know International is having trouble meeting the new standards even with urea. I was told our new Internationals will come with Cummins engines because they can meet smog.
Diesel is a heavier fuel, so it contains longer and more complex hydrocarbon molecules which, if partly burnt, form particles; soot, basically.
Gasoline molecules are smaller; once they break apart the remains are too volatile to create soot and will generally burn up too or form single CO molecules. Plus what me_and_my_metro said. |
Local research into diesel soot particles resulted in a bit of a surprise: If a participant had been stuck in traffic, it already showed ... They end up in your blood and go everywhere your blood takes them ... Quote:
There's more energy in natural gas by weight In HGV, up to some 70% diesel can be replaced by CNG - even retrofitted I burn less CNG than I'd burn diesel |
My diesel makes huge 100 to 250 micron particles.
With newer diesels they try to hide the particle matter and you end up with a lot of 1 to 3 micron diesel particles. It just so happens that is also the perfect size for bugs to be packaged in a biological weapon system. Because when inhaled it goes everywhere throughout the body. 100+ micron is like common dirt and dust, the body's defences filter it out. |
In Texas they are installing cng infrastructure mostly for big rig trucks but anyone can use it.
The first dedicated-CNG coach operating commercially in my hometown since May 2021, with a 320hp, 5-cyl 9.3L Scania engine. It's used for a charter service between Porto Alegre and Charqueadas. This year for the first time both Diesel fuel and CNG became more expensive than regular gasoline in Brazil, but some operators may favor CNG and biomethane over Diesel as there is no need for a complex aftertreatment system.
https://blogger.googleusercontent.co...e%20frente.jpg |
